GitLab
What's new
10
Support
Community forum
Keyboard shortcuts
vidjil
vidjil
8a42fa93
8a42fa93
Mathieu Giraud
should-vdj-to-tap.py: move Vidjil specific code to repseq_vdj.py
72637ad6
2
2 changed files
61 additions
54 deletions
+61
-54
algo/tests/repseq_vdj.py
+54
-1
algo/tests/should-vdj-to-tap.py
+7
-53
8a42fa93
@@ -10,8 +10,9 @@ python repsep_vdj.py data-curated/curated_TR.fa data-curated/curated_tr_Summary.
python repseq_vdj.py data-curated/mixcr.results > data-curated/mixcr.vdj
import
sys
import
sys
import
os
V
'V'
V
'V'
D
'D'
D
'D'
@@ -185,6 +186,58 @@ def header_vquest_results(ff_fasta, ff_vquest):
r
IMGT_VQUEST_Result
vquest
r
IMGT_VQUEST_Result
vquest
yield
fasta
replace
r
to_vdj
yield
fasta
replace
r
to_vdj
### Vidjil
VIDJIL_FINE
'{directory}/vidjil -X 100 -# "#" -c segment -i -3 -d -g {directory}/germline %s >> %s'
VIDJIL_KMER
'{directory}/vidjil -w 20 -# "#" -b out -c windows -uuuU -2 -i -g {directory}/germline %s > /dev/null ; cat out/out.segmented.vdj.fa out/out.unsegmented.vdj.fa >> %s'
def
should_results_from_vidjil_output
f_log
Yield (should, result) couples from a Vidjil output including lines in the form of:
>TRDD2*01_1/AGG/1_TRDD3*01__TRD+ + VJ 0 84 88 187 TRDD2*01 1/AGG/1 TRDD3*01 TRD+
>TRDV3*01_0//0_TRDJ4*01 ! + VJ 0 49 50 97 TRD UNSEG noisy
for
l
in
open
f_log
if
not
l
continue
if
l
l
l
strip
pos
l
find
if
in
l
else
l
find
should
l
pos
replace
'_'
pos
l
find
\t
result
l
pos
yield
should
result
def
program
f_should
f_log
Launch the program on f_should
Yields (#, >) couples of V(D)J designations, such as in:
#TRDD2*01 1/AGG/1 TRDD3*01 TRD+
>TRDD2*01 TRDD3*01
cmd
program
f_should
f_log
open
f_log
'w'
as
f
f
write
'# %s
\n\n
cmd
exit_code
os
system
cmd
if
exit_code
print
"Error. The program halted with exit code %s."
exit_code
sys
exit
3
return
f_log
### Main
if
__name__
'__main__'
if
__name__
'__main__'
if
'mixcr'
in
sys
argv
if
'mixcr'
in
sys
argv
8a42fa93
@@ -28,13 +28,11 @@ from collections import defaultdict
import
os
import
os
import
argparse
import
argparse
import
repseq_vdj
VIDJIL_FINE
VIDJIL_KMER
parser
argparse
ArgumentParser
formatter_class
argparse
RawTextHelpFormatter
parser
argparse
ArgumentParser
formatter_class
argparse
parser
add_argument
'--program'
'-p'
default
VIDJIL_FINE
help
'program to launch on each file (%(default)s)'
parser
add_argument
'--program'
'-p'
default
repseq_vdj
VIDJIL_FINE
help
parser
add_argument
'-q'
dest
'program'
action
'store_const'
const
VIDJIL_KMER
help
'shortcut for -p (VIDJIL_KMER), to be used with -2'
parser
add_argument
'-q'
dest
'program'
action
'store_const'
const
repseq_vdj
VIDJIL_KMER
help
parser
add_argument
'--ignore_N'
'-N'
action
'store_true'
help
'ignore N patterns, checking only gene and allele names'
parser
add_argument
'--ignore_N'
'-N'
action
'store_true'
help
parser
add_argument
'--ignore_allele'
'-A'
action
'store_true'
help
'ignore allele, checking only gene names'
parser
add_argument
'--ignore_allele'
'-A'
action
'store_true'
help
parser
add_argument
'--ignore_D'
'-D'
action
'store_true'
help
'ignore D gene names and alleles'
parser
add_argument
'--ignore_D'
'-D'
action
'store_true'
help
@@ -67,53 +65,6 @@ global_stats_failed = defaultdict(int)
global_stats_todo
defaultdict
int
global_stats_todo
defaultdict
int
def
should_result_from_vidjil
l
Return a (should, result) couple from a Vidjil output line in the form of:
l
l
strip
pos
l
find
if
in
l
else
l
find
should
l
pos
replace
'_'
pos
l
find
\t
result
l
pos
return
should
result
def
should_results_from_program
f_should
>TRDD2*01 TRDD3*01
f_log
f_should
PROG_TAG
LOG_SUFFIX
f_log
f_log
replace
SHOULD_SUFFIX
program
args
program
replace
'{directory}'
args
directory
cmd
program
f_should
f_log
open
f_log
'w'
as
f
f
write
'# %s
\n\n
cmd
exit_code
os
system
cmd
if
exit_code
print
exit_code
sys
exit
3
for
l
in
open
f_log
if
not
l
continue
if
l
yield
l
def
should_results_from_vdj
f_vdj
def
f_vdj
Parses a .vdj file
Parses a .vdj file
@@ -321,8 +272,11 @@ def should_to_tap_one_file(f_should):
f_tap
f_should
PROG_TAG
TAP_SUFFIX
f_tap
f_should
PROG_TAG
TAP_SUFFIX
f_tap
f_tap
replace
SHOULD_SUFFIX
f_tap
f_tap
replace
SHOULD_SUFFIX
f_log
f_should
PROG_TAG
LOG_SUFFIX
f_log
f_log
replace
SHOULD_SUFFIX
print
"<== %s"
f_should
print
"<== %s"
f_should
should_results
list
program
f_should
should_results
list
repseq_vdj
vidjil
args
program
replace
'{directory}'
args
directory
f_should
f_log
write_should_results_to_tap
should_results
f_tap
should_results
f_tap
