Commit 876a7cec authored by Mathieu Giraud's avatar Mathieu Giraud
doc/browser.org: keyboard shortcuts
parent 381aca00
...@@ -275,6 +275,30 @@ There can be several causes leading to bad ratios: ...@@ -275,6 +275,30 @@ There can be several causes leading to bad ratios:
* Keyboard shortcuts
** Browser
| =←= and =→= | navigate between samples |
| =Shift-←= and =Shift-→= | decrease or increase the number of displayed clones |
| =a=: TRA | |
| =b=: TRB | |
| =g=: TRG | |
| =d=: TRD, TRD+ | Change the selected germline/locus |
| =h=: IGH, IGH+ | |
| =l=: IGL | |
| =k=: IGK, IGK+) | |
** Browser connected to a patient databse
| =Ctrl-s= | save the analysis |
| =Shift-p= | open the 'patient' window |
* Browser API * Browser API
The browser can be opened on a data file specified from a =data= attribute, The browser can be opened on a data file specified from a =data= attribute,
