Commit 85709a8c authored by Mathieu Giraud's avatar Mathieu Giraud
tests: use getInfoLineWithAffects() to better debug failed tests
parent f9c91f2f
...@@ -114,87 +114,87 @@ void testSegmentationCause() { ...@@ -114,87 +114,87 @@ void testSegmentationCause() {
if (data.read(i).label == "seq-seg+") { if (data.read(i).label == "seq-seg+") {
TAP_TEST(ks.isSegmented(), TEST_KMER_IS_SEGMENTED, "seq is " << data.label(i)); TAP_TEST(ks.isSegmented(), TEST_KMER_IS_SEGMENTED, "seq is " << data.label(i));
TAP_TEST(ks.getSegmentationStatus() == SEG_PLUS, TEST_KMER_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == SEG_PLUS, TEST_KMER_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
TAP_TEST(ks.getJunction(30) == "GCCACCTGGGACAGGGAATTATTATAAGAA" TAP_TEST(ks.getJunction(30) == "GCCACCTGGGACAGGGAATTATTATAAGAA"
|| ks.getJunction(30) == "TGCCACCTGGGACAGGGAATTATTATAAGA", || ks.getJunction(30) == "TGCCACCTGGGACAGGGAATTATTATAAGA",
TEST_KMER_JUNCTION, ""); TEST_KMER_JUNCTION, ks.getInfoLineWithAffects());
TAP_TEST(ks.getLeft() == 17, TEST_KMER_LEFT, "left = " << ks.getLeft()); TAP_TEST(ks.getLeft() == 17, TEST_KMER_LEFT, "left = " << ks.getLeft());
TAP_TEST(ks.getRight() == 18, TEST_KMER_RIGHT, "right = " << ks.getRight()); TAP_TEST(ks.getRight() == 18, TEST_KMER_RIGHT, "right = " << ks.getRight());
ks.setSegmentationStatus(NOT_PROCESSED); ks.setSegmentationStatus(NOT_PROCESSED);
TAP_TEST(! ks.isSegmented(), TEST_SET_SEGMENTATION_CAUSE, ""); TAP_TEST(! ks.isSegmented(), TEST_SET_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
TAP_TEST(ks.getSegmentationStatus() == NOT_PROCESSED, TEST_SET_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == NOT_PROCESSED, TEST_SET_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
ks.setSegmentationStatus(UNSEG_NOISY); ks.setSegmentationStatus(UNSEG_NOISY);
TAP_TEST(ks.getSegmentationStatus() == UNSEG_NOISY, TEST_SET_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == UNSEG_NOISY, TEST_SET_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
ks.setSegmentationStatus(SEG_PLUS); ks.setSegmentationStatus(SEG_PLUS);
TAP_TEST(ks.isSegmented(), TEST_SET_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.isSegmented(), TEST_SET_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
TAP_TEST(ks.getSegmentationStatus(), TEST_SET_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus(), TEST_SET_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
nb_checked++; nb_checked++;
} else if (data.read(i).label == "seq-seg-") { } else if (data.read(i).label == "seq-seg-") {
TAP_TEST(ks.isSegmented(), TEST_KMER_IS_SEGMENTED, ""); TAP_TEST(ks.isSegmented(), TEST_KMER_IS_SEGMENTED, ks.getInfoLineWithAffects());
TAP_TEST(ks.getSegmentationStatus() == SEG_MINUS, TEST_KMER_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == SEG_MINUS, TEST_KMER_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
} else if (data.read(i).label == "seq-short") { } else if (data.read(i).label == "seq-short") {
TAP_TEST(! ks.isSegmented(), TEST_KMER_IS_SEGMENTED, ""); TAP_TEST(! ks.isSegmented(), TEST_KMER_IS_SEGMENTED, ks.getInfoLineWithAffects());
TAP_TEST(ks.getSegmentationStatus() == UNSEG_TOO_SHORT, TEST_KMER_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == UNSEG_TOO_SHORT, TEST_KMER_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
} else if (data.read(i).label == "seq-strand") { } else if (data.read(i).label == "seq-strand") {
TAP_TEST(ks.getSegmentationStatus() == UNSEG_STRAND_NOT_CONSISTENT, TEST_KMER_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == UNSEG_STRAND_NOT_CONSISTENT, TEST_KMER_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
} else if (data.read(i).label == "seq-zero") { } else if (data.read(i).label == "seq-zero") {
TAP_TEST(ks.getSegmentationStatus() == UNSEG_TOO_FEW_ZERO, TEST_KMER_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == UNSEG_TOO_FEW_ZERO, TEST_KMER_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
} else if (data.read(i).label == "seq-fewV") { } else if (data.read(i).label == "seq-fewV") {
TAP_TEST(ks.getSegmentationStatus() == UNSEG_TOO_FEW_V, TEST_KMER_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == UNSEG_TOO_FEW_V, TEST_KMER_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
} else if (data.read(i).label == "seq-fewJ") { } else if (data.read(i).label == "seq-fewJ") {
TAP_TEST(! ks.isSegmented(), TEST_KMER_IS_SEGMENTED, "fewJ: " << ks.getKmerAffectAnalyser()->toString()); TAP_TEST(! ks.isSegmented(), TEST_KMER_IS_SEGMENTED, "fewJ: " << ks.getInfoLineWithAffects());
TAP_TEST(ks.getSegmentationStatus() == UNSEG_TOO_FEW_J, TEST_KMER_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == UNSEG_TOO_FEW_J, TEST_KMER_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
} else if (data.read(i).label == "seq-fewV2") { } else if (data.read(i).label == "seq-fewV2") {
} else if (data.read(i).label == "seq-fewJ2") { } else if (data.read(i).label == "seq-fewJ2") {
} else if (data.read(i).label == "seq-delta-min-old") { } else if (data.read(i).label == "seq-delta-min-old") {
// This test was a test for delta_min but with the CountKmerAffectAnalyser // This test was a test for delta_min but with the CountKmerAffectAnalyser
// the read is segmented, now. So we keep it, but change the test // the read is segmented, now. So we keep it, but change the test
TAP_TEST(ks.isSegmented(), TEST_KMER_IS_SEGMENTED, "delta-min: " << ks.getKmerAffectAnalyser()->toString()); TAP_TEST(ks.isSegmented(), TEST_KMER_IS_SEGMENTED, "delta-min: " << ks.getInfoLineWithAffects());
TEST_KMER_JUNCTION, "junction: " << ks.getJunction(30)); TEST_KMER_JUNCTION, "junction: " << ks.getJunction(30));
} else if (data.read(i).label == "seq-delta-min") { } else if (data.read(i).label == "seq-delta-min") {
TAP_TEST(ks.getJunction(21) == "GGCAGTTGGAACAACACTTGT", TAP_TEST(ks.getJunction(21) == "GGCAGTTGGAACAACACTTGT",
TEST_KMER_JUNCTION, "window: " << ks.getJunction(21)); TEST_KMER_JUNCTION, "window: " << ks.getJunction(21));
TAP_TEST(ks.getLeft() == 9, TEST_KMER_LEFT, "left = " << ks.getLeft() << ", aa = " << ks.getKmerAffectAnalyser()->toString()); TAP_TEST(ks.getLeft() == 9, TEST_KMER_LEFT, "left = " << ks.getLeft() << ", " << ks.getInfoLineWithAffects());
TAP_TEST(ks.getRight() == 19, TEST_KMER_RIGHT, "right = " << ks.getRight()); TAP_TEST(ks.getRight() == 19, TEST_KMER_RIGHT, "right = " << ks.getRight() << ", " << ks.getInfoLineWithAffects());
} else if (data.read(i).label == "seq-delta-max") { } else if (data.read(i).label == "seq-delta-max") {
TAP_TEST(ks.getSegmentationStatus() == UNSEG_BAD_DELTA_MAX, TEST_KMER_SEGMENTATION_CAUSE, ""); TAP_TEST(ks.getSegmentationStatus() == UNSEG_BAD_DELTA_MAX, TEST_KMER_SEGMENTATION_CAUSE, ks.getInfoLineWithAffects());
} else if (data.read(i).label == "seq-seg-no-window") { } else if (data.read(i).label == "seq-seg-no-window") {
TAP_TEST(ks.getLeft() == 11, TEST_KMER_LEFT, "left = " << ks.getLeft()); TAP_TEST(ks.getLeft() == 11, TEST_KMER_LEFT, "left = " << ks.getLeft());
TAP_TEST(ks.getRight() == 12, TEST_KMER_RIGHT, "right = " << ks.getRight()); TAP_TEST(ks.getRight() == 12, TEST_KMER_RIGHT, "right = " << ks.getRight());
TAP_TEST(ks.getJunction(30) == "", TEST_KMER_JUNCTION, ""); TAP_TEST(ks.getJunction(30) == "", TEST_KMER_JUNCTION, ks.getInfoLineWithAffects());
TAP_TEST(ks.getJunction(20) == "CTGGGACAGGGAATTATTAT" TAP_TEST(ks.getJunction(20) == "CTGGGACAGGGAATTATTAT"
|| ks.getJunction(20) == "CCTGGGACAGGGAATTATTA", TEST_KMER_JUNCTION,"window: " << ks.getJunction(20)); || ks.getJunction(20) == "CCTGGGACAGGGAATTATTA", TEST_KMER_JUNCTION,"window: " << ks.getJunction(20));
