Commit 83a310a6 authored by Marc Duez's avatar Marc Duez
mains.js : parse/redirect url for custom result file
parent ab7dae4c
...@@ -94,6 +94,7 @@ if (typeof config != 'undefined' && location.search != ''){ ...@@ -94,6 +94,7 @@ if (typeof config != 'undefined' && location.search != ''){
var config = -1 var config = -1
var dataURL = "" var dataURL = ""
var analysisURL = "" var analysisURL = ""
var custom_list = []
for (var i=0; i<tmp.length; i++){ for (var i=0; i<tmp.length; i++){
var tmp2 = tmp[i].split('=') var tmp2 = tmp[i].split('=')
...@@ -101,6 +102,7 @@ if (typeof config != 'undefined' && location.search != ''){ ...@@ -101,6 +102,7 @@ if (typeof config != 'undefined' && location.search != ''){
if (tmp2[0] == 'analysis') analysisURL = tmp2[1] if (tmp2[0] == 'analysis') analysisURL = tmp2[1]
if (tmp2[0] == 'patient') patient = tmp2[1] if (tmp2[0] == 'patient') patient = tmp2[1]
if (tmp2[0] == 'config') config = tmp2[1] if (tmp2[0] == 'config') config = tmp2[1]
if (tmp2[0] == 'custom') custom_list.push(tmp2[1])
...@@ -117,6 +119,11 @@ if (typeof config != 'undefined' && location.search != ''){ ...@@ -117,6 +119,11 @@ if (typeof config != 'undefined' && location.search != ''){
//wait 1sec to check ssl //wait 1sec to check ssl
setTimeout(function () { db.load_data( {"patient" : patient , "config" : config } , "") }, 1000); setTimeout(function () { db.load_data( {"patient" : patient , "config" : config } , "") }, 1000);
if (custom_list.length>0){
setTimeout(function () { db.load_custom_data( {"custom" : custom_list }) }, 1000);
}else if (typeof config != 'undefined' && config.use_database){ }else if (typeof config != 'undefined' && config.use_database){
