Commit 8281b966 authored by Marc Duez's avatar Marc Duez
server: file info view, split info from sequence file and from run/config
parent d5522533
...@@ -18,12 +18,12 @@ patient = db.patient[request.vars["id"]] ...@@ -18,12 +18,12 @@ patient = db.patient[request.vars["id"]]
<h3>{{=patient.last_name + " " + patient.first_name}} ({{=request.vars["id"]}})</h3> <h3>{{=patient.last_name + " " + patient.first_name}} ({{=request.vars["id"]}})</h3>
<div class="db_top"> <div class="db_block">
<div class="db_top_left"> <div class="db_block_left">
file list file list
</div> </div>
<div class="db_top_right"> <div class="db_block_right">
choose config choose config
<span> <span>
<select id="choose_config" name="config" onchange="db.call('patient/info', {'id' :'{{=request.vars['id']}}', 'config_id' : this.value})"> <select id="choose_config" name="config" onchange="db.call('patient/info', {'id' :'{{=request.vars['id']}}', 'config_id' : this.value})">
...@@ -72,11 +72,21 @@ patient = db.patient[request.vars["id"]] ...@@ -72,11 +72,21 @@ patient = db.patient[request.vars["id"]]
for row in query :}} for row in query :}}
{{if row.sequence_file.data_file is None :}}
{{filename = ''}}
{{else:}}
{{(filename, str) = db.sequence_file.data_file.retrieve(row.sequence_file.data_file)}}
{{pass}}
<tr> <tr>
<td> {{ (filename, str) = db.sequence_file.data_file.retrieve(row.sequence_file.data_file)}} {{=filename}}</td> <td id="sequence_file_{{=row.sequence_file.id}}"> {{=filename}}</td>
<td> {{=row.sequence_file.sampling_date}} </td> <td> {{=row.sequence_file.sampling_date}} </td>
<td> {{=row.sequence_file.info}} </td> <td> {{=row.sequence_file.info}} </td>
<td> <a href="{{=URL('download', scheme='http', args=row.sequence_file.data_file)}}" >dl</a> </td> <td> {{if filename != '':}}
<a href="{{=URL('download', scheme='https', args=row.sequence_file.data_file)}}" >dl</a>
{{pass}}
</td>
<td onclick="db.call('file/edit', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > e </td> <td onclick="db.call('file/edit', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > e </td>
<td onclick="db.call('file/confirm', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > X </td> <td onclick="db.call('file/confirm', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > X </td>
...@@ -95,10 +105,20 @@ patient = db.patient[request.vars["id"]] ...@@ -95,10 +105,20 @@ patient = db.patient[request.vars["id"]]
</table> </table>
<table class="db_table" id="db_fixed_header"></table> <table class="db_table" id="db_fixed_header"></table>
</div> </div>
<span class="button" onclick="db.call('patient/index')"> back to list </span> <div class="db_block">
<span class="button" onclick="db.call('file/add', { 'id' : '{{=request.vars["id"]}}' } )"> add file </span> <div class="db_block_left">
<span class="button" onclick="db.load_data( { 'patient_id' : '{{=request.vars["id"]}}' , 'config_id' : {{=config_id}} } )" > see result </span> <span class="button" onclick="db.call('patient/index')"> back to list </span>
</div>
<span class="button" onclick="" > get .data </span>
<span class="button" onclick="" > get .analysis </span>
</div>
</div>
</div> </div>
{{elif 'content' in globals():}} {{elif 'content' in globals():}}
