Commit 81f717a2 authored by Ryan Herbert's avatar Ryan Herbert
file.py add action to data
parent 0d136614
Pipeline #19926 passed with stages
in 43 seconds
...@@ -247,6 +247,7 @@ def submit(): ...@@ -247,6 +247,7 @@ def submit():
f['id'] = fid = db.sequence_file.insert(**file_data) f['id'] = fid = db.sequence_file.insert(**file_data)
action = "add" action = "add"
data['action'] = action
f['message'] = [] f['message'] = []
mes = "file (%d) %s %sed" % (int(f["id"]), f["filename"], action) mes = "file (%d) %s %sed" % (int(f["id"]), f["filename"], action)
f['message'].append(mes) f['message'].append(mes)
