Commit 81b11bbd authored by Marc Duez's avatar Marc Duez
builder.js : update info windows
- info about current time/point
- can edit current time/point name
parent a3b8c49a
...@@ -306,28 +306,63 @@ Builder.prototype = { ...@@ -306,28 +306,63 @@ Builder.prototype = {
var parent = document.getElementById("info") var parent = document.getElementById("info")
parent.innerHTML=""; parent.innerHTML="";
//file name
var div_data_file = document.createElement('div'); var div_data_file = document.createElement('div');
div_data_file.id = "info_data_file" div_data_file.id = "info_data_file"
div_data_file.appendChild(document.createTextNode(this.m.dataFileName)); div_data_file.appendChild(document.createTextNode(this.m.dataFileName));
var div_analysis_file = document.createElement('div'); //global info
div_analysis_file.id = "info_analysis_file" var div_analysis_file = this.build_info_line("info_analysis_file", "analysis file" ,this.m.analysisFileName)
div_analysis_file.appendChild(document.createTextNode(this.m.analysisFileName)); var div_system = this.build_info_line("info_system", "system" ,this.m.system)
var div_system = document.createElement('div'); //point info
div_system.id = "info_system" var div_point = this.build_info_line("info_point", "point", this.m.time[this.point])
div_system.appendChild(document.createTextNode(this.m.system)); var span = document.createElement('span')
span.appendChild(document.createTextNode("..."));
span.className = "edit_button"
span.onclick = function(){ self.editPointName(this); }
div_point.appendChild(span)
var percent= (this.m.reads_segmented[this.point]/this.m.reads_total[this.point])*100
var val = ""+this.m.reads_segmented[this.point] + " reads"
+" ("+percent.toFixed(2)+"%)"
var div_segmented = this.build_info_line("info_segmented", "segmented", val)
var div_color = this.build_info_color() var div_total = this.build_info_line("info_total", "total" ,this.m.reads_total[this.point] + " reads")
parent.appendChild(div_data_file) parent.appendChild(div_data_file)
parent.appendChild(div_analysis_file) parent.appendChild(div_analysis_file)
parent.appendChild(div_system) parent.appendChild(div_system)
parent.appendChild(div_color)
parent.appendChild(div_point)
parent.appendChild(div_segmented)
parent.appendChild(div_total)
/*TODO put this somewhere else
//color
initTag(); initTag();
build_info_line : function (id, name, value) {
var span1 = document.createElement('span');
span1.appendChild(document.createTextNode(name+" : " ));
span1.className = "info_row"
var span2 = document.createElement('span');
span2.appendChild(document.createTextNode(value));
var div = document.createElement('div');
div.id = id
div.className = "info_line"
div.appendChild(span1)
div.appendChild(span2)
return div
build_info_color : function () { build_info_color : function () {
var self = this var self = this
