Commit 7c2a0a36 authored by Ryan Herbert's avatar Ryan Herbert
partial forms remove autocomplete on info input
parent fdadf96b
Pipeline #19996 failed with stages
in 40 seconds
...@@ -56,6 +56,7 @@ ...@@ -56,6 +56,7 @@
name="file[{{=i}}][info]" name="file[{{=i}}][info]"
rows="1" rows="1"
placeholder="sample information (#tags can be used)" placeholder="sample information (#tags can be used)"
autocomplete="off"
value="{{if 'info' in file and file['info'] is not None:}}{{=file['info']}}{{pass}}"/> value="{{if 'info' in file and file['info'] is not None:}}{{=file['info']}}{{pass}}"/>
</div> </div>
<div class="field_div"> <div class="field_div">
...@@ -22,5 +22,6 @@ ...@@ -22,5 +22,6 @@
name="generic[{{=i}}][info]" name="generic[{{=i}}][info]"
rows="1" rows="1"
placeholder="set information (#tags can be used)" placeholder="set information (#tags can be used)"
autocomplete="off"
value="{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}"/> value="{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}"/>
</div> </div>
...@@ -35,5 +35,6 @@ ...@@ -35,5 +35,6 @@
name="patient[{{=i}}][info]" name="patient[{{=i}}][info]"
rows="1" rows="1"
placeholder="patient information (#tags can be used)" placeholder="patient information (#tags can be used)"
autocomplete="off"
value="{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}" /> value="{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}" />
</div> </div>
...@@ -31,6 +31,7 @@ ...@@ -31,6 +31,7 @@
name="run[{{=i}}][info]" name="run[{{=i}}][info]"
rows="1" rows="1"
placeholder="run information (#tags can be used)" placeholder="run information (#tags can be used)"
autocomplete="off"
</div> </div>
