Commit 7bd5506d authored by Mathieu Giraud's avatar Mathieu Giraud
tools/should.py: update from upstream, 2.0.0
parent 7582cf96
...@@ -26,7 +26,7 @@ if not (sys.version_info >= (3, 4)): ...@@ -26,7 +26,7 @@ if not (sys.version_info >= (3, 4)):
print("Python >= 3.4 required") print("Python >= 3.4 required")
sys.exit(1) sys.exit(1)
__version_info__ = ('1','0','0') __version_info__ = ('2','0','0')
__version__ = '.'.join(__version_info__) __version__ = '.'.join(__version_info__)
import re import re
...@@ -66,6 +66,7 @@ VAR_LAUNCHER = '$LAUNCHER' ...@@ -66,6 +66,7 @@ VAR_LAUNCHER = '$LAUNCHER'
VAR_EXTRA = '$EXTRA' VAR_EXTRA = '$EXTRA'
MOD_TODO = 'f' MOD_TODO = 'f'
MOD_ALLOW = 'a'
MOD_REGEX = 'r' MOD_REGEX = 'r'
MOD_COUNT_ALL = 'w' MOD_COUNT_ALL = 'w'
MOD_IGNORE_CASE = 'i' MOD_IGNORE_CASE = 'i'
...@@ -96,6 +97,8 @@ SKIP = 'SKIP' ...@@ -96,6 +97,8 @@ SKIP = 'SKIP'
TODO = 'TODO' TODO = 'TODO'
TODO_PASSED = 'TODO_PASSED' TODO_PASSED = 'TODO_PASSED'
ALLOW_FAILED = 'ALLOW_FAILED'
STATUS = { STATUS = {
None: 'not run', None: 'not run',
False: 'failed', False: 'failed',
...@@ -103,9 +106,22 @@ STATUS = { ...@@ -103,9 +106,22 @@ STATUS = {
SKIP: 'skip', SKIP: 'skip',
TODO: 'TODO', TODO: 'TODO',
TODO_PASSED: 'TODO-but-ok', TODO_PASSED: 'TODO-but-ok',
ALLOW_FAILED: 'failed-but-ALLOW',
WARN_STATUS = [False, SKIP, TODO, TODO_PASSED] STATUS_ORDER = [
# Failed
False, TODO_PASSED,
# Warnings
TODO, ALLOW_FAILED, SKIP,
# Passed
True,
# 'Forgotten' status when mixed to other tests
None
FAIL_STATUS = [False, TODO_PASSED]
WARN_STATUS = FAIL_STATUS + [ALLOW_FAILED, TODO, SKIP]
STATUS_TAP = { STATUS_TAP = {
...@@ -114,6 +130,7 @@ STATUS_TAP = { ...@@ -114,6 +130,7 @@ STATUS_TAP = {
SKIP: 'ok # SKIP', SKIP: 'ok # SKIP',
TODO: 'not ok # TODO', TODO: 'not ok # TODO',
TODO_PASSED: 'ok # TODO', TODO_PASSED: 'ok # TODO',
ALLOW_FAILED: 'not ok # SKIP',
STATUS_XML = STATUS.copy() STATUS_XML = STATUS.copy()
...@@ -121,6 +138,22 @@ STATUS_XML[False] = 'failure' ...@@ -121,6 +138,22 @@ STATUS_XML[False] = 'failure'
STATUS_XML[SKIP] = 'skipped' STATUS_XML[SKIP] = 'skipped'
def combine_status(s1, s2):
>>> combine_status(TODO, False)
False
>>> combine_status(True, SKIP) == SKIP
True
>>> combine_status(True, TODO_PASSED) == TODO_PASSED
True
i1 = STATUS_ORDER.index(s1)
i2 = STATUS_ORDER.index(s2)
return STATUS_ORDER[min(i1,i2)]
# Simple colored output # Simple colored output
CSIm = '\033[%sm' CSIm = '\033[%sm'
...@@ -140,21 +173,23 @@ class ANSI: ...@@ -140,21 +173,23 @@ class ANSI:
def color(col, text, colorize = True): def color(col, text, colorize = True):
if not colorize: if not colorize:
return text return text
return CSIm % ANSI.BRIGHT + CSIm % col + text + CSIm % ANSI.RESET return CSIm % col + text + CSIm % ANSI.RESET
STATUS_COLORS = { STATUS_COLORS = {
None: ANSI.BLUE, None: ANSI.CYAN,
False: ANSI.RED, False: ANSI.RED,
True: ANSI.GREEN, True: ANSI.GREEN,
SKIP: ANSI.BLUE, SKIP: ANSI.CYAN,
TODO: ANSI.BLUE, TODO: ANSI.CYAN,
TODO_PASSED: ANSI.BLUE, TODO_PASSED: ANSI.RED,
ALLOW_FAILED: ANSI.CYAN,
# Modifier parser # Modifier parser
MODIFIERS = [ MODIFIERS = [
(MOD_TODO, 'todo', 'consider that the test should fail'), (MOD_TODO, 'todo', 'consider that the test should fail'),
(MOD_ALLOW, 'allow', 'consider that the test is allowed to fail'),
(MOD_REGEX, 'regex', 'consider as a regular expression'), (MOD_REGEX, 'regex', 'consider as a regular expression'),
(MOD_COUNT_ALL, 'count-all', 'count all occurrences, even on a same line'), (MOD_COUNT_ALL, 'count-all', 'count all occurrences, even on a same line'),
(MOD_IGNORE_CASE, 'ignore-case', 'ignore case changes'), (MOD_IGNORE_CASE, 'ignore-case', 'ignore case changes'),
...@@ -207,16 +242,17 @@ for (mod_char, mod_long, mod_help) in MODIFIERS: ...@@ -207,16 +242,17 @@ for (mod_char, mod_long, mod_help) in MODIFIERS:
parser = ArgParser(description='Test command-line applications through .should files', parser = ArgParser(description='Test command-line applications through .should files',
fromfile_prefix_chars='@', fromfile_prefix_chars='@',
epilog='''Example: epilog='''Example (see also README.md and demo/*.should):
%(prog)s demo/hello.should''', %(prog)s demo/hello.should''',
add_help=False,
formatter_class=argparse.RawTextHelpFormatter) formatter_class=argparse.RawTextHelpFormatter)
parser.add_argument('--version', action='version',
version='%(prog)s {version}'.format(version=__version__))
options = ArgParser(fromfile_prefix_chars='@') # Can be used in !OPTIONS: directive options = ArgParser(fromfile_prefix_chars='@') # Can be used in !OPTIONS: directive
for p in (parser, options): group = parser.add_argument_group('running tests (can also be set per test in !OPTIONS)')
for p in (group, options):
p.add_argument('--cd', metavar='PATH', help='directory from which to run the test commands') p.add_argument('--cd', metavar='PATH', help='directory from which to run the test commands')
p.add_argument('--cd-same', action='store_true', help='run the test commands from the same directory as the .should files') p.add_argument('--cd-same', action='store_true', help='run the test commands from the same directory as the .should files')
p.add_argument('--launcher', metavar='CMD', default='', help='launcher preceding each command (or replacing %s)' % VAR_LAUNCHER) p.add_argument('--launcher', metavar='CMD', default='', help='launcher preceding each command (or replacing %s)' % VAR_LAUNCHER)
...@@ -225,9 +261,17 @@ for p in (parser, options): ...@@ -225,9 +261,17 @@ for p in (parser, options):
p.add_argument('--var', metavar='NAME=value', action='append', help='variable definition (then use $NAME in .should files)') p.add_argument('--var', metavar='NAME=value', action='append', help='variable definition (then use $NAME in .should files)')
p.add_argument('--timeout', type=int, default = TIMEOUT, help = 'Delay (in seconds) after which the task is stopped (default: %(default)d)') p.add_argument('--timeout', type=int, default = TIMEOUT, help = 'Delay (in seconds) after which the task is stopped (default: %(default)d)')
parser.add_argument('--shuffle', action='store_true', help='shuffle the tests') group = parser.add_argument_group('selecting tests to be run')
group.add_argument('--shuffle', action='store_true', help='shuffle the tests')
group.add_argument('--no-a', action='store_true', help="do not launch 'a' tests")
group.add_argument('--no-f', action='store_true', help="do not launch 'f' tests")
group.add_argument('--only-a', action='store_true', help="launches only 'a' tests")
group.add_argument('--only-f', action='store_true', help="launches only 'f' tests")
output = parser.add_argument_group('output options') group.add_argument(RETRY_FLAG, action='store_true', help='launches only the last failed or warned tests')
output = parser.add_argument_group('controlling output')
output.add_argument('--log', action='append_const', dest='output', const=OUT_LOG, help='stores the output into .log files') output.add_argument('--log', action='append_const', dest='output', const=OUT_LOG, help='stores the output into .log files')
output.add_argument('--tap', action='append_const', dest='output', const=OUT_TAP, help='outputs .tap files') output.add_argument('--tap', action='append_const', dest='output', const=OUT_TAP, help='outputs .tap files')
...@@ -235,8 +279,13 @@ output.add_argument('--xml', action='append_const', dest='output', const=OUT_XML ...@@ -235,8 +279,13 @@ output.add_argument('--xml', action='append_const', dest='output', const=OUT_XML
output.add_argument('-v', '--verbose', action='count', help='increase verbosity', default=1) output.add_argument('-v', '--verbose', action='count', help='increase verbosity', default=1)
output.add_argument('-q', '--quiet', action='store_const', dest='verbose', const=0, help='verbosity to zero') output.add_argument('-q', '--quiet', action='store_const', dest='verbose', const=0, help='verbosity to zero')
output.add_argument('--fail-a', action='store_true', help="fail on passing 'a' tests")
output.add_argument("-h", "--help", action="help", help="show this help message and exit")
output.add_argument('--version', action='version',
parser.add_argument('file', metavar='should-file', nargs='+', help='''input files (.should)''') parser.add_argument('file', metavar='should-file', nargs='+', help='''input files (.should)''')
parser.add_argument(RETRY_FLAG, action='store_true', help='launch again the last failed or warned tests')
class ShouldException(BaseException): class ShouldException(BaseException):
pass pass
...@@ -355,6 +404,12 @@ class Stats(): ...@@ -355,6 +404,12 @@ class Stats():
def items(self): def items(self):
return self.stats.items() return self.stats.items()
def __iter__(self):
'''Ordered according to STATUS_ORDER'''
for key in STATUS_ORDER[::-1]:
if key in self.keys():
yield (key, self[key])
def values(self): def values(self):
return self.stats.values() return self.stats.values()
...@@ -372,10 +427,15 @@ class Stats(): ...@@ -372,10 +427,15 @@ class Stats():
s = '==> ' s = '==> '
s += STATUS[status] s += STATUS[status]
s += ' - ' s += ' - '
s += ' '.join(['%s:%d' % (STATUS[key], len(val)) for (key, val) in self.items()] + ['total:%s' % self.total()]) s = color(STATUS_COLORS[status], s, colorize)
s += ' '.join([color(STATUS_COLORS[key], '%s:%d', colorize) % (STATUS[key], len(val)) for (key, val) in self])
nb_items = '- total:%s' % self.total()
if self.item: if self.item:
s += ' ' + self.item + ('s' if self.total() > 1 else '') nb_items += ' ' + self.item + ('s' if self.total() > 1 else '')
return color(STATUS_COLORS[status], s, colorize) s += ' ' + color(STATUS_COLORS[status], nb_items, colorize)
return s
...@@ -426,6 +486,7 @@ class ExternalTestCase(TestCaseAbstract): ...@@ -426,6 +486,7 @@ class ExternalTestCase(TestCaseAbstract):
self.name = name self.name = name
self.status = status self.status = status
self.info = info self.info = info
self.modifiers = ''
def str_additional_status(self, verbose = False): def str_additional_status(self, verbose = False):
s = '' s = ''
...@@ -578,6 +639,8 @@ class TestCase(TestCaseAbstract): ...@@ -578,6 +639,8 @@ class TestCase(TestCaseAbstract):
if self.mods.todo: if self.mods.todo:
self.status = [TODO, TODO_PASSED][self.status] self.status = [TODO, TODO_PASSED][self.status]
if self.mods.allow:
self.status = [ALLOW_FAILED, True][self.status]
if verbose > 0: if verbose > 0:
print('') print('')
...@@ -602,12 +665,7 @@ class TestCase(TestCaseAbstract): ...@@ -602,12 +665,7 @@ class TestCase(TestCaseAbstract):
class TestSuite(): class TestSuite():
>>> s = TestSuite() >>> s = TestSuite()
>>> s.load(['echo "hello"', '$My test', ':hello']) >>> s.test(['echo "hello"', '$My test', ':hello'], colorize = False)
>>> print(s)
echo "hello"
My test
>>> s.test()
True True
>>> s.tests[0].status >>> s.tests[0].status
True True
...@@ -615,8 +673,7 @@ class TestSuite(): ...@@ -615,8 +673,7 @@ class TestSuite():
>>> s2 = TestSuite('r') >>> s2 = TestSuite('r')
>>> s2.variables.append(("$LAUNCHER", "")) >>> s2.variables.append(("$LAUNCHER", ""))
>>> s2.variables.append(("$EXTRA", "")) >>> s2.variables.append(("$EXTRA", ""))
>>> s2.load(['echo "hello"', '$ A nice test', ':e.*o']) >>> s2.test(['echo "hello"', '$ A nice test', ':e.*o'], verbose = 1, colorize = False) # doctest: +NORMALIZE_WHITESPACE
>>> s2.test(verbose = 1, colorize = False) # doctest: +NORMALIZE_WHITESPACE
echo "hello" echo "hello"
stdout --> 1 lines stdout --> 1 lines
stderr --> 0 lines stderr --> 0 lines
...@@ -625,7 +682,7 @@ class TestSuite(): ...@@ -625,7 +682,7 @@ class TestSuite():
True True
>>> s2.str_status(colorize = False) >>> s2.str_status(colorize = False)
'==> ok - ok:2 total:2 tests' '==> ok - ok:2 - total:2 tests'
>>> print(s2.tap()) # doctest: +NORMALIZE_WHITESPACE >>> print(s2.tap()) # doctest: +NORMALIZE_WHITESPACE
1..2 1..2
...@@ -643,9 +700,12 @@ class TestSuite(): ...@@ -643,9 +700,12 @@ class TestSuite():
self.stdin = [] self.stdin = []
self.stdout = [] self.stdout = []
self.test_lines = [] self.test_lines = []
self.skip = False
self.status = None self.status = None
self.modifiers = modifiers self.modifiers = modifiers
self.opt_modifiers = ''
self.variables = [] self.variables = []
self.status = None
self.stats = Stats('test') self.stats = Stats('test')
self.source = None self.source = None
self.cd = cd self.cd = cd
...@@ -654,10 +714,25 @@ class TestSuite(): ...@@ -654,10 +714,25 @@ class TestSuite():
self.elapsed_time = None self.elapsed_time = None
self.timeout = timeout self.timeout = timeout
def load(self, should_lines): def cmd_variables_cd(self, cmd, verbose, colorize):
cmd = replace_variables(cmd, self.variables_all)
if self.cd:
cmd = 'cd %s ; ' % self.cd + cmd
if verbose > 0:
print(color(ANSI.MAGENTA, cmd, colorize))
return cmd
def test(self, should_lines, variables=[], verbose=0, colorize=True, only=None):
name = '' name = ''
this_cmd_continues = False current_cmd = '' # multi-line command
for l in should_lines: current_cmds = [] # commands since the last command run
current_tests = [] # tests since the last command run
self.only = only
self.variables_all = self.variables + variables
# Iterate over should_lines
# then use once DIRECTIVE_SCRIPT to flush the last tests
for l in list(should_lines) + [DIRECTIVE_SCRIPT]:
l = l.lstrip().rstrip(ENDLINE_CHARS) l = l.lstrip().rstrip(ENDLINE_CHARS)
if not l: if not l:
...@@ -670,16 +745,29 @@ class TestSuite(): ...@@ -670,16 +745,29 @@ class TestSuite():
# Directive -- Requires # Directive -- Requires
if l.startswith(DIRECTIVE_REQUIRES): if l.startswith(DIRECTIVE_REQUIRES):
self.requires_cmd = l[len(DIRECTIVE_REQUIRES):].strip() self.requires_cmd = l[len(DIRECTIVE_REQUIRES):].strip()
requires_cmd = self.cmd_variables_cd(self.requires_cmd, verbose, colorize)
p = subprocess.Popen(requires_cmd, shell=True, stdout=subprocess.DEVNULL, stderr=subprocess.PIPE)
self.requires = (p.wait() == 0)
self.requires_stderr = [l.decode(errors='replace') for l in p.stderr.readlines()]
if not self.requires:
self.skip_set('Condition is not met: %s' % self.requires_cmd, verbose)
if verbose > 0:
print(color(ANSI.CYAN, ''.join(self.requires_stderr), colorize))
continue continue
# Directive -- No launcher # Directive -- No launcher
if l.startswith(DIRECTIVE_NO_LAUNCHER): if l.startswith(DIRECTIVE_NO_LAUNCHER):
self.use_launcher = False self.use_launcher = False
if replace_variables(VAR_LAUNCHER, self.variables_all):
self.skip_set('%s while %s is given' % (DIRECTIVE_NO_LAUNCHER, VAR_LAUNCHER), verbose)
continue continue
# Directive -- No extra options # Directive -- No extra options
if l.startswith(DIRECTIVE_NO_EXTRA): if l.startswith(DIRECTIVE_NO_EXTRA):
self.variables = [(VAR_EXTRA, '')] + self.variables self.variables = [(VAR_EXTRA, '')] + self.variables
continue continue
# Directive -- Source # Directive -- Source
...@@ -691,8 +779,8 @@ class TestSuite(): ...@@ -691,8 +779,8 @@ class TestSuite():
if l.startswith(DIRECTIVE_OPTIONS): if l.startswith(DIRECTIVE_OPTIONS):
opts, unknown = options.parse_known_args(l[len(DIRECTIVE_OPTIONS):].split()) opts, unknown = options.parse_known_args(l[len(DIRECTIVE_OPTIONS):].split())
self.variables = populate_variables(opts.var) + self.variables self.variables = populate_variables(opts.var) + self.variables
if opts.mod: self.variables_all = self.variables + variables
self.modifiers += ''.join(opts.mod) self.opt_modifiers = ''.join(opts.mod) if opts.mod else ''
continue continue
# Directive -- Exit code # Directive -- Exit code
...@@ -718,73 +806,60 @@ class TestSuite(): ...@@ -718,73 +806,60 @@ class TestSuite():
if RE_TEST.search(l): if RE_TEST.search(l):
pos = l.find(TOKEN_TEST) pos = l.find(TOKEN_TEST)
modifiers, expression = l[:pos], l[pos+1:] modifiers, expression = l[:pos], l[pos+1:]
self.tests.append(TestCase(self.modifiers + modifiers, expression, name)) test = TestCase(modifiers + self.opt_modifiers + self.modifiers, expression, name)
current_tests.append(test)
self.tests.append(test)
continue continue
# Command
# Command : flush and test the previous tests
# If the command is empty (for example at the ned), launch previous commands even when there are no tests
l = l.strip() l = l.strip()
next_cmd_continues = l.endswith(CONTINUATION_CHAR)
if next_cmd_continues:
l = l[:-1]
if this_cmd_continues: if current_tests or not l:
self.cmds[-1] += l
else:
self.cmds.append(l)
this_cmd_continues = next_cmd_continues # Test current_cmds with current_tests
if not self.skip:
test_lines, exit_test = self.launch(current_cmds, verbose, colorize)
current_tests.append(exit_test)
self.test_lines += test_lines
self.tests_on_lines(current_tests, test_lines, verbose, colorize)
self.debug(self.status, "\n".join(current_cmds), test_lines, verbose, colorize)
else:
self.skip_tests(current_tests)
current_cmds = []
current_tests = []
def print_stderr(self, colorize=True): # Command
print(' stdout --> %s lines' % len(self.stdout)) if not l:
print(' stderr --> %s lines' % len(self.stderr)) continue
print(color(ANSI.CYAN, ''.join(self.stderr), colorize))
def skip_all(self, reason, verbose=1): next_cmd_continues = l.endswith(CONTINUATION_CHAR)
if verbose > 0: if next_cmd_continues:
print('Skipping tests: %s' % reason) l = l[:-1]
for test in self.tests:
test.status = SKIP
self.stats.up(test.status)
self.status = SKIP
def test(self, variables=[], verbose=0, colorize=True): current_cmd += l
self.variables_all = self.variables + variables if not next_cmd_continues:
if verbose > 1: current_cmds.append(current_cmd)
print_variables(self.variables_all) self.cmds.append(current_cmd)
current_cmd = ''
def cmd_variables_cd(cmd):
if self.cd:
if verbose > 0:
return cmd
self.status = True # end of loop on should_lines
if self.requires_cmd: if verbose > 1:
requires_cmd = cmd_variables_cd(self.requires_cmd) print_variables(self.variables_all)
if verbose > 0:
if not self.requires: return self.status
self.skip_all('Condition is not met: %s' % self.requires_cmd, verbose)
return self.status
if not self.use_launcher:
self.skip_all('%s while %s is given' % (DIRECTIVE_NO_LAUNCHER, VAR_LAUNCHER), verbose)
return self.status
def launch(self, cmds, verbose, colorize):
start_time = time.time() start_time = time.time()
cmd = ' ; '.join(map(pre_process, self.cmds)) cmd = ' ; '.join(map(pre_process, cmds))
cmd = cmd_variables_cd(cmd) cmd = self.cmd_variables_cd(cmd, verbose, colorize)
f_stdout = tempfile.TemporaryFile() f_stdout = tempfile.TemporaryFile()
f_stderr = tempfile.TemporaryFile() f_stderr = tempfile.TemporaryFile()
...@@ -794,12 +869,19 @@ class TestSuite(): ...@@ -794,12 +869,19 @@ class TestSuite():
try: try:
self.exit_code = p.wait(self.timeout) self.exit_code = p.wait(self.timeout)
self.tests.append(ExternalTestCase('Exit code is %d' % self.expected_exit_code, self.exit_code == self.expected_exit_code, str(self.exit_code))) exit_test = ExternalTestCase('Exit code is %d' % self.expected_exit_code, self.exit_code == self.expected_exit_code, str(self.exit_code))
except subprocess.TimeoutExpired: except subprocess.TimeoutExpired:
self.exit_code = None self.exit_code = None
self.tests.append(ExternalTestCase('Exit code is %d' % self.expected_exit_code, SKIP, 'timeout after %s seconds' % self.timeout)) exit_test = ExternalTestCase('Exit code is %d' % self.expected_exit_code, SKIP, 'timeout after %s seconds' % self.timeout)
p.kill() p.kill()
self.tests.append(exit_test)
self.status = combine_status(self.status, exit_test.status)
if self.elapsed_time is None:
self.elapsed_time = 0
self.elapsed_time += time.time() - start_time
f_stdout.seek(0) f_stdout.seek(0)
f_stderr.seek(0) f_stderr.seek(0)
self.stdout = [l.decode(errors='replace') for l in f_stdout.readlines()] self.stdout = [l.decode(errors='replace') for l in f_stdout.readlines()]
...@@ -807,45 +889,67 @@ class TestSuite(): ...@@ -807,45 +889,67 @@ class TestSuite():
f_stdout.close() f_stdout.close()
f_stderr.close() f_stderr.close()
self.print_stderr(colorize) self.print_stderr(colorize)
self.test_lines = open(self.source).readlines() if self.source else self.stdout return open(self.source).readlines() if self.source else self.stdout, exit_test
test.test(self.test_lines, variables=self.variables_all, verbose=verbose-1)
# When a test fails, the file fails
if test.status is False:
self.status = False
# When the file is not failing, we may report a more sublte status def tests_on_lines(self, tests, test_lines, verbose, colorize):
if test.status in WARN_STATUS and self.status is True: '''
self.status = test.status Test all tests in 'tests' on 'test_lines',
taking into accound self modifiers
and gathering statuses in self.status
for test in tests:
# Filter
if self.only:
if not self.only(test):
test.status = SKIP
continue
# Test the test
test.test(test_lines, variables=self.variables_all, verbose=verbose-1)
self.status = combine_status(self.status, test.status)
if verbose > 0 or test.status in WARN_STATUS: if verbose > 0 or test.status in WARN_STATUS:
print(test.str(colorize)) print(test.str(colorize))
if self.status is False and verbose <= 0: def print_stderr(self, colorize=True):
def skip_set(self, reason, verbose=1):
if verbose > 0:
self.skip = True
self.status = combine_status(self.status, SKIP)
def skip_tests(self, tests):
for test in tests:
test.status = SKIP
def debug(self, status, cmd, test_lines, verbose, colorize):
if status in FAIL_STATUS and verbose <= 0:
print(color(ANSI.MAGENTA, cmd, colorize)) print(color(ANSI.MAGENTA, cmd, colorize))
if self.status is False or verbose > 1: if status in FAIL_STATUS or verbose > 1:
print(LINE)
