GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
78d1abe0
78d1abe0
Mathieu Giraud
Committed by
Vidjil Team
Aug 04, 2016
views/patient: 'results' instead of 'configs'
This column provide direct links to results.
7ce99015
server/web2py/applications/vidjil/views/patient/index.html
78d1abe0
@@ -24,7 +24,7 @@
@@ -24,7 +24,7 @@
<td
class=
"pointer"
onclick=
"db.call('patient/index', {'sort' :'info', 'filter' : '{{=request.vars["
filter
<td
class=
"pointer"
onclick=
filter
if
not
reverse
request.vars
sort
="info"
reverse
true
pass
info
</td>
if
not
reverse
request.vars
sort
="info"
reverse
true
pass
info
</td>
<td
class=
"pointer"
class=
"column_100"
onclick=
"db.call('patient/index', {'sort' :'configs', 'filter' : '{{=request.vars["
filter
<td
class=
"pointer"
class=
"column_100"
onclick=
filter
if
not
reverse
request.vars
sort
="configs"
reverse
true
pass
config
s
</td>
if
not
reverse
request.vars
sort
="configs"
reverse
true
pass
result
s
</td>
{{if isAdmin:}}
<td
class=
"column_100 pointer"
onclick=
"db.call('patient/index', {'sort' :'groups', 'filter' : '{{=request.vars["
filter
{{if isAdmin:}}
<td
class=
onclick=
filter
if
not
reverse
request.vars
sort
="groups"
reverse
true
pass
groups
</td>
{{pass}}
if
not
reverse
request.vars
sort
="groups"
reverse
true
pass
groups
</td>
{{pass}}
{{if isAdmin:}}
<td
class=
onclick=
"db.call('patient/index', {'sort' :'creator', 'filter' : '{{=request.vars["
filter
{{if isAdmin:}}
<td
class=
onclick=
filter
