Commit 6ff70780 authored by Téo Vasseur's avatar Téo Vasseur
index.html : remove 'checked' attribute duplication in input, and remove empty line
parent 5d49c516
Pipeline #2177 failed with stages
in 2 minutes and 41 seconds
...@@ -198,7 +198,6 @@ ...@@ -198,7 +198,6 @@
normalization method</br> normalization method</br>
<label for="menuNormMethConstant" class="buttonSelector" onclick="m.changeNormMethod('constant')" ><input id="menuNormMethConstant" type="radio" name="normalize_method" value="constant" checked />constant</label> <label for="menuNormMethConstant" class="buttonSelector" onclick="m.changeNormMethod('constant')" ><input id="menuNormMethConstant" type="radio" name="normalize_method" value="constant" checked />constant</label>
<label for="menuNormMethPercent" class="buttonSelector" onclick="m.changeNormMethod('to-100')" ><input id="menuNormMethPercent" type="radio" name="normalize_method" value="to-100" />to 100%</label> <label for="menuNormMethPercent" class="buttonSelector" onclick="m.changeNormMethod('to-100')" ><input id="menuNormMethPercent" type="radio" name="normalize_method" value="to-100" />to 100%</label>
</div> </div>
<div class="menu_box"> <div class="menu_box">
...@@ -210,7 +209,7 @@ ...@@ -210,7 +209,7 @@
sample key</br> sample key</br>
<label for="menuTimeFormName" class="buttonSelector" onclick="m.changeTimeFormat('name', true)"><input id="menuTimeFormName" type="radio" name="time" value="name" checked />name</label> <label for="menuTimeFormName" class="buttonSelector" onclick="m.changeTimeFormat('name', true)"><input id="menuTimeFormName" type="radio" name="time" value="name" checked />name</label>
<label for="menuTimeFormShort" class="buttonSelector" onclick="m.changeTimeFormat('short_name', true)"><input id="menuTimeFormShort" type="radio" name="time" value="short_name" checked />name (short)</label> <label for="menuTimeFormShort" class="buttonSelector" onclick="m.changeTimeFormat('short_name', true)"><input id="menuTimeFormShort" type="radio" name="time" value="short_name"/>name (short)</label>
<label for="menuTimeFormSample" class="buttonSelector" onclick="m.changeTimeFormat('sampling_date', true)"><input id="menuTimeFormSample" type="radio" name="time" value="sampling_date" />sampling date</label> <label for="menuTimeFormSample" class="buttonSelector" onclick="m.changeTimeFormat('sampling_date', true)"><input id="menuTimeFormSample" type="radio" name="time" value="sampling_date" />sampling date</label>
<label for="menuTimeFormSamplePlus" class="buttonSelector" onclick="m.changeTimeFormat('delta_date', true)"><input id="menuTimeFormSamplePlus" type="radio" name="time" value="delta_date" />day after first sample</label> <label for="menuTimeFormSamplePlus" class="buttonSelector" onclick="m.changeTimeFormat('delta_date', true)"><input id="menuTimeFormSamplePlus" type="radio" name="time" value="delta_date" />day after first sample</label>
</div> </div>
