GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
6c33abdd
6c33abdd
Mathieu Giraud
should-vdj-to-tap.py: bikeshed output, 'unexpected' locus
9aa54572
Pipeline
#65672
failed with stages
in 29 minutes and 44 seconds
algo/tests/should-vdj-to-tap.py
6c33abdd
@@ -336,9 +336,9 @@ if __name__ == '__main__':
print
"=== Summary, should-vdj tests ==="
' (only locus)'
if
args
after_two
else
print
' (only locus)'
if
args
after_two
else
print
" tested passed bug failed (todo)"
print
for
locus
in
sorted
global_stats
for
locus
in
sorted
global_stats
print
5
s %4d %4d %4d %4d %4s"
locus
global_stats
locus
global_stats
locus
global_stats_failed
locus
global_stats_bug
locus
global_stats_failed
locus
print
10
locus
global_stats
locus
global_stats
locus
global_stats_failed
locus
global_stats_bug
locus
global_stats_failed
locus
"(%d)"
global_stats_todo
locus
if
global_stats_todo
locus
else
"(%d)"
global_stats_todo
locus
if
global_stats_todo
locus
else
print
" ===== %4d %4d %4d %4d %4s"
sum
global_stats
values
sum
global_stats
values
sum
global_stats_failed
values
sum
global_stats_bug
values
sum
global_stats_failed
values
print
sum
global_stats
values
sum
global_stats
values
sum
global_stats_failed
values
sum
global_stats_bug
values
sum
global_stats_failed
values
"(%d)"
sum
global_stats_todo
values
"(%d)"
sum
global_stats_todo
values
print
print
