Commit 686ae38b authored by Mathieu Giraud's avatar Mathieu Giraud Committed by Vidjil Team
patient/info.html: display 'pcr' in the samples table
parent b7fad767
...@@ -101,6 +101,7 @@ ...@@ -101,6 +101,7 @@
<td class="column5"> </td> <td class="column5"> </td>
<td class="column2"> sampling date </td> <td class="column2"> sampling date </td>
<td> info </td> <td> info </td>
<td> pcr </td>
...@@ -129,6 +130,7 @@ ...@@ -129,6 +130,7 @@
<td> {{if row.sequence_file.filename == 'plop':}}<a href="{{=URL('patient','download', scheme='https', args=row.sequence_file.data_file)}}" >dl</a>{{pass}}</td> <td> {{if row.sequence_file.filename == 'plop':}}<a href="{{=URL('patient','download', scheme='https', args=row.sequence_file.data_file)}}" >dl</a>{{pass}}</td>
<td> {{=row.sequence_file.sampling_date}} </td> <td> {{=row.sequence_file.sampling_date}} </td>
<td> {{=row.sequence_file.info}} </td> <td> {{=row.sequence_file.info}} </td>
<td> {{=row.sequence_file.pcr}} </td>
{{if (auth.has_permission('admin', 'patient', request.vars["id"]) ):}} {{if (auth.has_permission('admin', 'patient', request.vars["id"]) ):}}
<td onclick="db.call('file/edit', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > e </td> <td onclick="db.call('file/edit', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > e </td>
<td onclick="db.call('file/confirm', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > X </td> <td onclick="db.call('file/confirm', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > X </td>
