GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
6829d3ed
6829d3ed
Marc Duez
patient view > display only available config
39525cc9
server/web2py/applications/vidjil/views/patient/info.html
6829d3ed
@@ -127,15 +127,18 @@
<div
class=
"db_block_right"
<div
class=
"db_block_right"
see the result:
see the result:
{{for row in db(db.fused_file.patient_id == request.vars["id"]).select() :}}
{{for row in db( (db.fused_file.patient_id == request.vars["id"])
{{filename = vidjil_utils.anon(request.vars["id"], auth.user_id) + " (" + db.config[row.config_id].name + ")"}}
(auth.accessible_query('read', db.config) | auth.accessible_query('admin', db.config) )
{{if row.fused_file is not None :}}
(db.config.id ==db.fused_file.config_id)
<a
class=
"button2"
href=
"index.html?patient={{=request.vars["
id
config=
{{=row.config_id}}"
type=
"text/html"
).select() :}}
{{filename = vidjil_utils.anon(request.vars["id"], auth.user_id) + " (" + row.config.name + ")"}}
{{if row.fused_file.fused_file is not None :}}
<a
class=
"button2"
href=
id
config=
{{=row.config.id}}"
type=
"text/html"
onclick=
"event.preventDefault()
onclick=
if( event.which == 2 ) { window.open(this.href) }
else { db.load_data( { 'patient' : '{{=request.vars["
id
config
row.config
_
id
filename
id
config
row.config
id
filename
{{pass}}
{{pass}}
db.config[
row.config
_id]
.name}}
</a>
{{=row.config.name}}
</a>
{{pass}}
{{pass}}
</div>
</div>
