Commit 6829d3ed authored by Marc Duez's avatar Marc Duez
patient view > display only available config
parent 39525cc9
...@@ -127,15 +127,18 @@ ...@@ -127,15 +127,18 @@
<div class="db_block_right"> <div class="db_block_right">
see the result: see the result:
{{for row in db(db.fused_file.patient_id == request.vars["id"]).select() :}} {{for row in db( (db.fused_file.patient_id == request.vars["id"]) &
{{filename = vidjil_utils.anon(request.vars["id"], auth.user_id) + " (" + db.config[row.config_id].name + ")"}} (auth.accessible_query('read', db.config) | auth.accessible_query('admin', db.config) ) &
{{if row.fused_file is not None :}} (db.config.id ==db.fused_file.config_id)
<a class="button2" href="index.html?patient={{=request.vars["id"]}}&config={{=row.config_id}}" type="text/html" ).select() :}}
{{filename = vidjil_utils.anon(request.vars["id"], auth.user_id) + " (" + row.config.name + ")"}}
{{if row.fused_file.fused_file is not None :}}
<a class="button2" href="index.html?patient={{=request.vars["id"]}}&config={{=row.config.id}}" type="text/html"
onclick="event.preventDefault() onclick="event.preventDefault()
if( event.which == 2 ) { window.open(this.href) } if( event.which == 2 ) { window.open(this.href) }
else { db.load_data( { 'patient' : '{{=request.vars["id"]}}' , 'config' : {{=row.config_id}} }, '{{=filename}}' ) }" > else { db.load_data( { 'patient' : '{{=request.vars["id"]}}' , 'config' : {{=row.config.id}} }, '{{=filename}}' ) }" >
{{pass}} {{pass}}
{{=db.config[row.config_id].name}} </a> {{=row.config.name}} </a>
{{pass}} {{pass}}
</div> </div>
