Commit 66e87171 authored by Mathieu Giraud's avatar Mathieu Giraud
vidjil.cpp: output representative coverage in .json, fix
Arbitrary fields must begin by '_' to be displayed in the browser,
and we should export a JsonArray that will be gathered in fuse.py.
parent 0a9ee9f1
...@@ -1206,7 +1206,9 @@ int main (int argc, char **argv) ...@@ -1206,7 +1206,9 @@ int main (int argc, char **argv)
JsonList json_clone; JsonList json_clone;
JsonList json_seg; JsonList json_seg;
json_clone.add("coverage", repComp.getCoverage()); JsonArray json_coverage;
json_coverage.add(repComp.getCoverage());
json_clone.add("_coverage", json_coverage);
// From FineSegmenter // From FineSegmenter
json_clone.add("sequence", seg.getSequence().sequence); json_clone.add("sequence", seg.getSequence().sequence);
