Commit 62f5c39f authored by Mathieu Giraud's avatar Mathieu Giraud
should-vdj-tests: BRI_IGK, check all 5 failures
- 3 sequences with 2 conserved nucleotides after a mutation -> alternative solution
- 2 other sequences -> actual bug
parent c2d34887
...@@ -9,7 +9,8 @@ GTGGCAGCCCAGGGCGACTCCTCATGAGTCTGCAGCTGC ...@@ -9,7 +9,8 @@ GTGGCAGCCCAGGGCGACTCCTCATGAGTCTGCAGCTGC
#target 0732EC #target 0732EC
>IGKV2D-30*01 17/AG/0 KDE [IGK] #15//0 is too permissive
>IGKV2D-30*01 17/AG/0 KDE [IGK] BUG
ACAGTGATGGAACACCTACTTGAATTGGTTTCAGCAGAGGCCAGGCCAATCTCCAAGGCGCCTAATTTATAA ACAGTGATGGAACACCTACTTGAATTGGTTTCAGCAGAGGCCAGGCCAATCTCCAAGGCGCCTAATTTATAA
GGTTTCTAACTGGGACTCTGGGGTCCCAGACA GGTTTCTAACTGGGACTCTGGGGTCCCAGACA
GATTCAGCGGCAGTGGGTCAGGCACTGATTTCACACTGAAAATCAGCAGGGTGGAGGCTGAGGATGTTGGGG GATTCAGCGGCAGTGGGTCAGGCACTGATTTCACACTGAAAATCAGCAGGGTGGAGGCTGAGGATGTTGGGG
...@@ -29,7 +30,8 @@ ATTTTTGCCATATCCACTATTTGGAGTCTGACCTCCCTAGGAAGCCTCCCTGCTCCCTAGGACAACCTGCTC ...@@ -29,7 +30,8 @@ ATTTTTGCCATATCCACTATTTGGAGTCTGACCTCCCTAGGAAGCCTCCCTGCTCCCTAGGACAACCTGCTC
#target 0862PT #target 0862PT
>IGKV2-30*01 15/CAC/15 KDE [IGK] #end of IGKV2-30*01/15 is ...aaggTac
>IGKV2-30*01 (12//15, 15/CAC/15) KDE [IGK]
GATTCAGTGGCAGTGGGTCAGGCACTGATTTCACACTGAAAATCAGCAGGGTGGAGGCTGAGGATGTTGGGG GATTCAGTGGCAGTGGGTCAGGCACTGATTTCACACTGAAAATCAGCAGGGTGGAGGCTGAGGATGTTGGGG
TTTATTACTGCATGCAAGGCACGCCCAGGGCGACTCCTCATGAGTCTGCAGCTGC TTTATTACTGCATGCAAGGCACGCCCAGGGCGACTCCTCATGAGTCTGCAGCTGC
...@@ -74,7 +76,8 @@ TTTATTACTGCATGCAAGCTACACAATTTCCTCATGTAGGGCGACTCCTCATGAGTCTGCAGCTGC ...@@ -74,7 +76,8 @@ TTTATTACTGCATGCAAGCTACACAATTTCCTCATGTAGGGCGACTCCTCATGAGTCTGCAGCTGC
#target 1026TM #target 1026TM
>IGKV1-39*01 1/GCGCCTTCTCCAGG/5 KDE [IGK] #start of KDE/2 is agCcct...
>IGKV1-39*01 (1/GCGCCTTCTCC/2, 1/GCGCCTTCTCCAGG/5) KDE [IGK]
AGGTTCAGTGGCAGTGGATCTGGGACAGATTTCACTCTCACCATCAGCAGTCTGCAACCTGAAGATTTTGCA AGGTTCAGTGGCAGTGGATCTGGGACAGATTTCACTCTCACCATCAGCAGTCTGCAACCTGAAGATTTTGCA
ACTTACTACTGTCAACAGAGTTACAGTACCCCTC ACTTACTACTGTCAACAGAGTTACAGTACCCCTC
GCGCCTTCTCCAGG GCGCCTTCTCCAGG
...@@ -91,7 +94,8 @@ GGAGCCCTAGTGGCAGCCCAGGGCGACTCCTCATGAGTCTGCAGCTGC ...@@ -91,7 +94,8 @@ GGAGCCCTAGTGGCAGCCCAGGGCGACTCCTCATGAGTCTGCAGCTGC
#target 1089IH #target 1089IH
>IGKV2-30*01 8/ACTGAGG/5 KDE [IGK] #8/ACT/1 is too permissive
>IGKV2-30*01 8/ACTGAGG/5 KDE [IGK] BUG
TTTATTACTGCATGCAAGGTACACACACTGAGGCCTAGTGGCAGCCCAGGGCGACTCCTCATGAGTCTGCAG TTTATTACTGCATGCAAGGTACACACACTGAGGCCTAGTGGCAGCCCAGGGCGACTCCTCATGAGTCTGCAG
CTGC CTGC
...@@ -107,7 +111,8 @@ GAGCCCTAGTGGCAGCCCAGGGCGACTCCTCATGAGTCTGCAGCTGC ...@@ -107,7 +111,8 @@ GAGCCCTAGTGGCAGCCCAGGGCGACTCCTCATGAGTCTGCAGCTGC
#target 1200CT #target 1200CT
>IGKV1-17*01 3/CCC/16 KDE [IGK] #end of IGKV1-17*10 is ...tacccTcc
>IGKV1-17*01 (0//16, 3/CCC/16) KDE [IGK]
GGGGTCCCATCAAGGTTCAGCGGCAGTGGATCTGGGACAGAATTCACTCTCACAATCAGCAGCCTGCAGCCT GGGGTCCCATCAAGGTTCAGCGGCAGTGGATCTGGGACAGAATTCACTCTCACAATCAGCAGCCTGCAGCCT
GAAGATTTTGCAACTTATTACTGTCTACAGCATAATAGTTACCC GAAGATTTTGCAACTTATTACTGTCTACAGCATAATAGTTACCC
CCC CCC
