Commit 6155a06b authored by Marc Duez's avatar Marc Duez
server : db.py > compatibility with mysql // remove init db
parent 116db4f4
...@@ -15,6 +15,7 @@ request.requires_https() ...@@ -15,6 +15,7 @@ request.requires_https()
if not request.env.web2py_runtime_gae: if not request.env.web2py_runtime_gae:
## if NOT running on Google App Engine use SQLite or other DB ## if NOT running on Google App Engine use SQLite or other DB
db = DAL('sqlite://storage.sqlite',pool_size=1,check_reserved=['all']) db = DAL('sqlite://storage.sqlite',pool_size=1,check_reserved=['all'])
## db = DAL('mysql://root:password@localhost/vidjil5',pool_size=1,check_reserved=['all'])
else: else:
## connect to Google BigTable (optional 'google:datastore://namespace') ## connect to Google BigTable (optional 'google:datastore://namespace')
db = DAL('google:datastore') db = DAL('google:datastore')
...@@ -94,8 +95,7 @@ db.define_table('patient', ...@@ -94,8 +95,7 @@ db.define_table('patient',
Field('birth','date'), Field('birth','date'),
Field('info','text'), Field('info','text'),
Field('id_label','string'), Field('id_label','string'),
Field('creator','reference auth_user') Field('creator','reference auth_user'))
db.patient.first_name.requires = IS_NOT_EMPTY( error_message='input needed' ) db.patient.first_name.requires = IS_NOT_EMPTY( error_message='input needed' )
...@@ -118,7 +118,7 @@ db.define_table('sequence_file', ...@@ -118,7 +118,7 @@ db.define_table('sequence_file',
Field('provider','reference auth_user'), Field('provider','reference auth_user'),
Field('data_file', 'upload', Field('data_file', 'upload',
uploadfolder=defs.DIR_SEQUENCES, uploadfolder=defs.DIR_SEQUENCES,
length=1000000000000, autodelete=True)) length=4294967295, autodelete=True))
...@@ -128,7 +128,7 @@ db.define_table('standard_file', ...@@ -128,7 +128,7 @@ db.define_table('standard_file',
autodelete=True, length=1000000000000)) autodelete=True, length=4294967295))
...@@ -147,17 +147,17 @@ db.define_table('results_file', ...@@ -147,17 +147,17 @@ db.define_table('results_file',
Field('scheduler_task_id', 'integer'), Field('scheduler_task_id', 'integer'),
uploadfolder=defs.DIR_RESULTS, uploadfolder=defs.DIR_RESULTS,
db.define_table('fused_file', db.define_table('fused_file',
Field('patient_id', 'reference patient'), Field('patient_id', 'reference patient'),
Field('config_id', 'reference config'), Field('config_id', 'reference config'),
Field('fuse_date','datetime'), Field('fuse_date','datetime', default="1970-01-01 00:00:00"),
Field('status', 'string'), Field('status', 'string'),
Field('sequence_file_list', 'string'), Field('sequence_file_list', 'string'),
Field('fused_file', 'upload', Field('fused_file', 'upload',
db.define_table('analysis_file', db.define_table('analysis_file',
...@@ -166,52 +166,8 @@ db.define_table('analysis_file', ...@@ -166,52 +166,8 @@ db.define_table('analysis_file',
Field('analysis_file', 'upload', Field('analysis_file', 'upload',
if db(db.auth_user.id > 0).count() == 0:
id_first_user=""
## création du premier user
id_first_user=db.auth_user.insert(
password = db.auth_user.password.validate('1234')[0],
email = 'plop@plop.com',
first_name = 'System',
last_name = 'Administrator'
## création des groupes de base
id_admin_group=db.auth_group.insert(role='admin')
id_sa_group=db.auth_group.insert(role='user_1')
db.auth_group.insert(role="public")
db.auth_membership.insert(user_id=id_first_user, group_id=id_admin_group)
db.auth_membership.insert(user_id=id_first_user, group_id=id_sa_group)
##création des configs de base
id_config_TRG = db.config.insert(
name = 'TRG',
command = '-c clones -z 100 -R 1 -r 1 -G germline/TRG ',
info = 'default trg config'
id_config_IGH = db.config.insert(
name = 'IGH',
command = '-c clones -d -z 100 -R 1 -r 1 -G germline/IGH ',
info = 'default igh config'
## permission
## system admin have admin/read/create rights on all patients, groups and configs
auth.add_permission(id_admin_group, 'admin', db.patient, 0)
auth.add_permission(id_admin_group, 'admin', db.auth_group, 0)
auth.add_permission(id_admin_group, 'admin', db.config, 0)
auth.add_permission(id_admin_group, 'read', db.patient, 0)
auth.add_permission(id_admin_group, 'read', db.auth_group, 0)
auth.add_permission(id_admin_group, 'read', db.config, 0)
auth.add_permission(id_admin_group, 'create', db.patient, 0)
auth.add_permission(id_admin_group, 'create', db.auth_group, 0)
auth.add_permission(id_admin_group, 'create', db.config, 0)
## after defining tables, uncomment below to enable auditing ## after defining tables, uncomment below to enable auditing
Supports Markdown
