Commit 5e5a9cb3 authored by Mathieu Giraud's avatar Mathieu Giraud
Merge branch 'release-template' into 'dev'
Release template
See merge request !905
parents bcbc5043 8cec2597
Pipeline #212963 failed with stages
in 35 minutes and 17 seconds
...@@ -26,13 +26,19 @@ Benchmarks ...@@ -26,13 +26,19 @@ Benchmarks
* [ ] almost no change... * [ ] almost no change...
* [ ] ... or significant changes are understood * [ ] ... or significant changes are understood
Profiling
* cpu: PointerACAutomaton.getResults, ~37% ?
* mem: PointerACAutomaton.insert, ~73% ?
## The release, publish, tag and push ## The release, publish, tag and push
* [ ] merge this MR to *master* and tag: `git tag release-20XX-XX` * [ ] merge this MR to *master* and tag: `git tag release-20XX-XX`
* [ ] push: `git push origin master release-20XX-XX` * [ ] push: `git push origin master release-20XX-XX`
* [ ] mirror to GH: `git push github master release-20XX.XX` * [ ] mirror to GH: `git push github master release-20XX.XX`
* [ ] click `publish_release` (there may be changes to CD...) * [ ] deploy to vidjil.org/releases and app.vidjil.org: click on `copy_release` (there may be changes to CD...)
* [ ] deploy the doc * [ ] deploy the doc: click on `deploy_doc`
After these steps, we merge back the release in `dev`: After these steps, we merge back the release in `dev`:
...@@ -43,6 +49,7 @@ After these steps, we merge back the release in `dev`: ...@@ -43,6 +49,7 @@ After these steps, we merge back the release in `dev`:
* [ ] Click `deploy_release_prod` in the `deploy_prod` stage, deploying the release on `vidjil-algo-next` on the public server * [ ] Click `deploy_release_prod` in the `deploy_prod` stage, deploying the release on `vidjil-algo-next` on the public server
* [ ] Open a new internal issue with the `Deploy (vidjil-algo)` template : vdj#XXXXX * [ ] Open a new internal issue with the `Deploy (vidjil-algo)` template : vdj#XXXXX
* [ ] Possibly fix things in `merge_request_templates/Release (vidjil-algo).md` on a new MR
/label ~cpp /label ~cpp
