Commit 5e34eb60 authored by Ryan Herbert's avatar Ryan Herbert
testRunner.py exit with representative code
We want our testRunner script to exit with an error code if tests
failed for gitlab-ci
parent 2cc87aee
Pipeline #18359 failed with stages
in 31 seconds
...@@ -330,4 +330,6 @@ for test_file in test_files: ...@@ -330,4 +330,6 @@ for test_file in test_files:
suite.addTest(unittest.makeSuite(globals()[filename+directory])) suite.addTest(unittest.makeSuite(globals()[filename+directory]))
#unittest.TextTestRunner(verbosity=2).run(suite) #unittest.TextTestRunner(verbosity=2).run(suite)
xmlrunner.XMLTestRunner(output='test-reports', verbosity=1).run(suite) result = xmlrunner.XMLTestRunner(output='test-reports', verbosity=1).run(suite)
sys.exit(not result.wasSuccessful())
Supports Markdown
