Commit 5b526072 authored by Marc Duez's avatar Marc Duez
server : unactive standard
- standard not needed anymore to create a config
- standard link removed form layout
- standard info removed from config list
parent 53513d59
...@@ -38,8 +38,6 @@ def add_form(): ...@@ -38,8 +38,6 @@ def add_form():
error += "name needed, " error += "name needed, "
if request.vars['config_info'] == "" : if request.vars['config_info'] == "" :
error += "info needed, " error += "info needed, "
if request.vars['config_standard'] == "" :
error += "standard needed, "
if request.vars['config_command'] == "" : if request.vars['config_command'] == "" :
error += "command needed, " error += "command needed, "
...@@ -47,7 +45,6 @@ def add_form(): ...@@ -47,7 +45,6 @@ def add_form():
db.config.insert(name=request.vars['config_name'], db.config.insert(name=request.vars['config_name'],
info=request.vars['config_info'], info=request.vars['config_info'],
standard_id=request.vars['config_standard'],
command=request.vars['config_command'], command=request.vars['config_command'],
...@@ -80,8 +77,6 @@ def edit_form(): ...@@ -80,8 +77,6 @@ def edit_form():
...@@ -89,11 +84,11 @@ def edit_form(): ...@@ -89,11 +84,11 @@ def edit_form():
db.config[request.vars["id"]] = dict(name=request.vars['config_name'], db.config[request.vars["id"]] = dict(name=request.vars['config_name'],
res = {"success": "true" } res = {"redirect": "config/index",
"message": "config saved"}
return gluon.contrib.simplejson.dumps(res, separators=(',',':')) return gluon.contrib.simplejson.dumps(res, separators=(',',':'))
else : else :
...@@ -120,5 +115,6 @@ def delete(): ...@@ -120,5 +115,6 @@ def delete():
#delete config #delete config
db(db.config.id==request.vars["id"]).delete() db(db.config.id==request.vars["id"]).delete()
"message": "config deleted"}
...@@ -115,7 +115,6 @@ db.define_table('standard_file', ...@@ -115,7 +115,6 @@ db.define_table('standard_file',
db.define_table('config', db.define_table('config',
Field('standard_id', 'reference standard_file'),
Field('name', 'string'), Field('name', 'string'),
Field('command', 'string'), Field('command', 'string'),
Field('info','text')) Field('info','text'))
...@@ -13,6 +13,7 @@ ...@@ -13,6 +13,7 @@
<td > <td >
</td> </td>
</tr> </tr>
<tr> <tr>
<td> <td>
<label for="config_standard" id="config_standard__label"> standard: </label> <label for="config_standard" id="config_standard__label"> standard: </label>
...@@ -29,6 +30,7 @@ ...@@ -29,6 +30,7 @@
<td> <td>
</td> </td>
</tr> </tr>
<tr> <tr>
<td> <td>
<label for="config_command" id="config_command__label">Command: </label> <label for="config_command" id="config_command__label">Command: </label>
...@@ -13,6 +13,7 @@ info = db.config[request.vars["id"]] ...@@ -13,6 +13,7 @@ info = db.config[request.vars["id"]]
<td > <input class="string" id="config_name" name="config_name" type="text" value="{{=info.name}}"> </td> <td > <td > <input class="string" id="config_name" name="config_name" type="text" value="{{=info.name}}"> </td> <td >
</td> </td>
</tr> </tr>
<tr> <tr>
<td> <label for="config_standard" id="config_standard__label"> standard: </label> </td> <td> <label for="config_standard" id="config_standard__label"> standard: </label> </td>
<td> <td>
...@@ -30,6 +31,7 @@ info = db.config[request.vars["id"]] ...@@ -30,6 +31,7 @@ info = db.config[request.vars["id"]]
</td> </td>
<td> </td> <td> </td>
</tr> </tr>
<tr> <tr>
<td> <label for="config_command" id="config_command__label">Command: </label> </td> <td> <label for="config_command" id="config_command__label">Command: </label> </td>
<td> <input class="string" id="config_command" name="config_command" type="text" value="{{=info.command}}"> </td> <td> <input class="string" id="config_command" name="config_command" type="text" value="{{=info.command}}"> </td>
...@@ -10,7 +10,6 @@ ...@@ -10,7 +10,6 @@
<table class="db_table" id="table"> <table class="db_table" id="table">
<thead> <thead>
<tr><td class="column2"> name </td> <tr><td class="column2"> name </td>
<td class="column2"> standard </td>
<td> info </td> <td> info </td>
<td> command </td> <td> command </td>
<td class="column5"> </td> <td class="column5"> </td>
...@@ -20,15 +19,14 @@ ...@@ -20,15 +19,14 @@
query = None query = None
c_id = "" c_id = ""
query = db(db.config.standard_id==db.standard_file.id).select() query = db(db.config).select()
for row in query :}} for row in query :}}
<tr> <tr>
<td> {{=row.config.name }} </td> <td> {{=row.name }} </td>
<td> {{=row.standard_file.name}} </td> <td> {{=row.info }} </td>
<td> {{=row.config.info }} </td> <td> {{=row.command }} </td>
<td> {{=row.config.command }} </td> <td onclick="db.call('config/edit', {'id' :'{{=row.id}}'} )" > e </td>
<td onclick="db.call('config/edit', {'id' :'{{=row.config.id}}'} )" > e </td> <td onclick="db.call('config/confirm', {'id' :'{{=row.id}}'} )" > X </td>
<td onclick="db.call('config/confirm', {'id' :'{{=row.config.id}}'} )" > X </td>
</tr> </tr>
{{pass}} {{pass}}
</table> </table>
...@@ -2,7 +2,6 @@ ...@@ -2,7 +2,6 @@
<div id="db_menu"> <div id="db_menu">
<a class="button" onclick="db.call('patient/index');">patients</a> <a class="button" onclick="db.call('patient/index');">patients</a>
<a class="button" onclick="db.call('standard/index');">standards</a>
<a class="button" onclick="db.call('config/index');">configs</a> <a class="button" onclick="db.call('config/index');">configs</a>
<a class="button" onclick="db.call('group/index');">groups</a> <a class="button" onclick="db.call('group/index');">groups</a>
