Commit 5b3bf354 authored by Mikaël Salson's avatar Mikaël Salson
Server: Missing column in patient info view
Column for download was not set (empty) for classical users
parent 92caa9eb
...@@ -77,7 +77,7 @@ ...@@ -77,7 +77,7 @@
<td onclick="db.call('file/confirm', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > X </td> <td onclick="db.call('file/confirm', {'id' :'{{=row.sequence_file.id}}', 'patient_id' :'{{=request.vars['id']}}'} )" > X </td>
<td> <a {{if row.sequence_file.data_file == None :}} {{=XML("class='inactive' title='file is missing' ")}} <td> <a {{if row.sequence_file.data_file == None :}} {{=XML("class='inactive' title='file is missing' ")}}
{{else:}} href="{{=URL('patient','download', scheme='https', args=row.sequence_file.data_file)}}" {{pass}} >dl</a></td> {{else:}} href="{{=URL('patient','download', scheme='https', args=row.sequence_file.data_file)}}" {{pass}} >dl</a></td>
{{else:}}<td></td><td></td>{{pass}} {{else:}}<td></td><td></td><td></td>{{pass}}
<td class="column_sep"></td> <td class="column_sep"></td>
