Commit 58026abe authored by Mathieu Giraud's avatar Mathieu Giraud
Makefile: make cppcheck, static code checking
parent 2f770eb7
...@@ -73,6 +73,15 @@ unit_coveralls: ...@@ -73,6 +73,15 @@ unit_coveralls:
should_coveralls: should_coveralls:
coveralls --exclude release --exclude algo/lib --exclude algo/tests --exclude algo/tools --exclude tests --exclude tools --exclude lib --gcov-options '\-lp' -r algo coveralls --exclude release --exclude algo/lib --exclude algo/tests --exclude algo/tools --exclude tests --exclude tools --exclude lib --gcov-options '\-lp' -r algo
### cppcheck
cppcheck:
mkdir -p reports
cppcheck --enable=all --xml . 2>! reports/cppcheck.xml
data germline: %: data germline: %:
make -C $@ make -C $@
