Commit 56fe4fa9 authored by Mikaël Salson's avatar Mikaël Salson
server/Makefile: Create the directory where web2py expects
parent ad6b171e
...@@ -18,7 +18,7 @@ unit: clean_unit_tests ...@@ -18,7 +18,7 @@ unit: clean_unit_tests
cd web2py; python web2py.py -S vidjil -M -R testRunner.py cd web2py; python web2py.py -S vidjil -M -R testRunner.py
standalone_install: install_unit_tests standalone_install: install_unit_tests
mkdir -p web2py/applications/vidjil/databases upload result mkdir -p web2py/applications/vidjil/databases web2py/upload web2py/result
sed -i 's@/var/vidjil@logs@' web2py/applications/vidjil/modules/defs.py sed -i 's@/var/vidjil@logs@' web2py/applications/vidjil/modules/defs.py
sed -i '/mysql/d; /^DIR_/s/\/mnt\///; s/PORT_FUSE_SERVER = .*/PORT_FUSE_SERVER = None/' web2py/applications/vidjil/modules/defs.py sed -i '/mysql/d; /^DIR_/s/\/mnt\///; s/PORT_FUSE_SERVER = .*/PORT_FUSE_SERVER = None/' web2py/applications/vidjil/modules/defs.py
