Commit 5651c8e9 authored by Mathieu Giraud's avatar Mathieu Giraud
Apply suggestion to browser/js/segmenter.js
parent 8d810cdb
Pipeline #151663 passed with stages
in 13 minutes and 7 seconds
...@@ -1572,6 +1572,7 @@ Sequence.prototype = Object.create(genSeq.prototype); ...@@ -1572,6 +1572,7 @@ Sequence.prototype = Object.create(genSeq.prototype);
highlights.push({'type':'N', 'color': "", 'start': vdjArray["3"].start}); highlights.push({'type':'N', 'color': "", 'start': vdjArray["3"].start});
highlights.push({'type':'before5', 'color': "black", 'start': 0}); // from seq start to 5 start highlights.push({'type':'before5', 'color': "black", 'start': 0}); // from seq start to 5 start
highlights.push({'type':'after3', 'color': "black", 'start': vdjArray["3"].stop}); // from 3 stop to seq end highlights.push({'type':'after3', 'color': "black", 'start': vdjArray["3"].stop}); // from 3 stop to seq end
// TOOD: remove the two previous lines, see #2135
var key; var key;
for (var i in SEGMENT_KEYS) { for (var i in SEGMENT_KEYS) {
