GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
554b5760
554b5760
Mikaël Salson
Merge branch 'feature-a/3444-artificats-junit' into 'dev'
Feature a/3444 artifacts junit Closes
#3444
See merge request
!289
parents
28032dd0
506b0050
Pipeline
#40836
passed with stages
in 5 minutes and 33 seconds
2
.gitlab-ci.yml
554b5760
@@ -28,8 +28,8 @@ stages:
# Anchors
# Anchors
.coverage_dependency
&lcov_artifact
artifacts
artifacts
&lcov_artifact
paths
paths
algo/lcov_test_*.filtered
expire_in
6hrs
expire_in
6hrs
@@ -58,6 +58,7 @@ test_germlines:
test_algo_unit
test_algo_unit
stage
test_unit
stage
test_unit
script
make -C algo unit_coverage
script
artifacts
*lcov_artifact
*lcov_artifact
only
only
/^feature-.*a.*\/.*$/
@@ -66,14 +67,18 @@ test_algo_unit:
test_algo_should
test_algo_should
stage
test_functional
stage
test_functional
script
make -C algo should_coverage
script
artifacts
*lcov_artifact
reports
junit
algo/tests/should.xml
only
only
schedules
schedules
*lcov_artifact
test_algo_shouldvdj
test_algo_shouldvdj
stage
test_shouldvdj
stage
test_shouldvdj
script
make -C algo shouldvdj_coverage
script
artifacts
*lcov_artifact
*lcov_artifact
only
only
algo/tests/Makefile
554b5760
@@ -71,7 +71,7 @@ snapshot_diff_current:
should
vidjil
should
vidjil
python3 should.py
$(SHOULD)
python3 should.py
--xml
$(SHOULD)
shouldvdj_if_python
shouldvdj_if_python
if
python ../../tools/check_python_version.py
if
