Commit 50c032e4 authored by Mikaël Salson's avatar Mikaël Salson
Merge branch 'feature-t/3950-igrec-parser' into 'dev'
Feature t/3950 igrec parser
Closes #3950
See merge request !493
parents 9836a025 42dfd8c9
Pipeline #86494 passed with stages
in 6 minutes and 44 seconds
...@@ -2,12 +2,13 @@ ...@@ -2,12 +2,13 @@
Parses output of various RepSeq programs. Parses output of various RepSeq programs.
Takes either: Takes either:
- a .fa file, a _Summary.txt file as produced by IMGT/V-QUEST - a .fa file, a _Summary.txt file as produced by IMGT/V-QUEST
- or a results file produced by MiXCR - or a results file produced by MiXCR or IgReC
and creates a .vdj file to be checked by should-vdj-to-tap.py and creates a .vdj file to be checked by should-vdj-to-tap.py
python repseq_vdj.py data-curated/curated_IG.fa data-curated/curated_ig_Summary.txt > data-curated/imgt-IG.vdj python repseq_vdj.py data-curated/curated_IG.fa data-curated/curated_ig_Summary.txt > data-curated/imgt-IG.vdj
python repsep_vdj.py data-curated/curated_TR.fa data-curated/curated_tr_Summary.txt > data-curated/imgt-TR.vdj python repsep_vdj.py data-curated/curated_TR.fa data-curated/curated_tr_Summary.txt > data-curated/imgt-TR.vdj
python repseq_vdj.py data-curated/mixcr.results > data-curated/mixcr.vdj python repseq_vdj.py data-curated/mixcr.results > data-curated/mixcr.vdj
python repseq_vdj.py bla.igrec.results
python repseq_vdj.py data-curated/curated_IG.fa data-curated/igblast/IG/*.aln > data-curated/igblast-IG.vdj > data-curated/igblast-IG.vdj python repseq_vdj.py data-curated/curated_IG.fa data-curated/igblast/IG/*.aln > data-curated/igblast-IG.vdj > data-curated/igblast-IG.vdj
python repseq_vdj.py data-curated/curated_TR.fa data-curated/igblast/TR/*.aln > data-curated/igblast-TR.vdj > data-curated/igblast-TR.vdj python repseq_vdj.py data-curated/curated_TR.fa data-curated/igblast/TR/*.aln > data-curated/igblast-TR.vdj > data-curated/igblast-TR.vdj
...@@ -98,6 +99,49 @@ class Result(VDJ_Formatter): ...@@ -98,6 +99,49 @@ class Result(VDJ_Formatter):
return str(self.d) return str(self.d)
### IgReC
IGREC_LABELS = [
'Read id', 'locus',
'V id', 'V start', 'V end', 'V score',
'J id', 'J start', 'J end', 'J score',
class IgReC_Result(Result):
r'''
>>> lig = '\t'.join(['blabli4577', 'TRB', 'TRBV13*02', '1', '164', '0.58156', 'TRBJ1-5*01', '319', '367', '0.94'])
>>> r = IgReC_Result(lig)
>>> r['Read id']
'blabli4577'
>>> r.vdj[V]
['TRBV13*02']
>>> r.vdj[J]
['TRBJ1-5*01']
def parse(self, l):
self.labels = IGREC_LABELS
if ('\t' in l.strip()):
return l
else:
return None
def populate(self):
self.vdj[V] = [self['V id']]
self.vdj[J] = [self['J id']]
def header_igrec_results(ff_igrec):
f = open(ff_igrec).__iter__()
while True:
l = f.next()
result = IgReC_Result(l)
yield result['Read id'], result.to_vdj()
### MiXCR ### MiXCR
...@@ -354,6 +398,8 @@ if __name__ == '__main__': ...@@ -354,6 +398,8 @@ if __name__ == '__main__':
if 'mixcr' in sys.argv[1]: if 'mixcr' in sys.argv[1]:
vdj.parse_from_gen(header_mixcr_results(sys.argv[1])) vdj.parse_from_gen(header_mixcr_results(sys.argv[1]))
elif 'igrec' in sys.argv[1]:
vdj.parse_from_gen(header_igrec_results(sys.argv[1]))
elif 'igblast' in sys.argv[2]: elif 'igblast' in sys.argv[2]:
vdj.parse_from_gen(header_igblast_results(sys.argv[1], sys.argv[2:])) vdj.parse_from_gen(header_igblast_results(sys.argv[1], sys.argv[2:]))
else: else:
...@@ -16,6 +16,7 @@ doctests: ...@@ -16,6 +16,7 @@ doctests:
python -m doctest -v ../utils.py python -m doctest -v ../utils.py
python -m doctest -v ../vidjil-to-fasta.py python -m doctest -v ../vidjil-to-fasta.py
python -m doctest -v ../../algo/tests/should-vdj-to-tap.py python -m doctest -v ../../algo/tests/should-vdj-to-tap.py
python -m doctest -v ../../algo/tests/repseq_vdj.py
python ../org-babel-tangle.py --test python ../org-babel-tangle.py --test
@echo "*** All python tests passed" @echo "*** All python tests passed"
