Commit 507ea3b0 authored by Mathieu Giraud's avatar Mathieu Giraud
lib/json.hpp: Works with g++ 4.8 (for us), again
Replays 42e01d24. Thanks to @mikael-s.
parent d15253c2
Pipeline #31164 passed with stages
in 45 seconds
...@@ -123,7 +123,7 @@ using json = basic_json<>; ...@@ -123,7 +123,7 @@ using json = basic_json<>;
#error "unsupported Clang version - see https://github.com/nlohmann/json#supported-compilers" #error "unsupported Clang version - see https://github.com/nlohmann/json#supported-compilers"
#endif #endif
#elif defined(__GNUC__) && !(defined(__ICC) || defined(__INTEL_COMPILER)) #elif defined(__GNUC__) && !(defined(__ICC) || defined(__INTEL_COMPILER))
#if (__GNUC__ * 10000 + __GNUC_MINOR__ * 100 + __GNUC_PATCHLEVEL__) < 40900 #if (__GNUC__ * 10000 + __GNUC_MINOR__ * 100 + __GNUC_PATCHLEVEL__) < 40800
#error "unsupported GCC version - see https://github.com/nlohmann/json#supported-compilers" #error "unsupported GCC version - see https://github.com/nlohmann/json#supported-compilers"
#endif #endif
#endif #endif
