GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
506b0050
506b0050
Mathieu Giraud
Committed by
Mikaël Salson
Sep 24, 2018
.gitlab-ci.yml: Make lcov_artifact and junit artifacts cohabitate
See
!289
6812904e
Pipeline
#40749
passed with stages
in 41 minutes and 25 seconds
.gitlab-ci.yml
506b0050
@@ -28,8 +28,8 @@ stages:
# Anchors
# Anchors
.coverage_dependency
&lcov_artifact
artifacts
artifacts
&lcov_artifact
paths
paths
algo/lcov_test_*.filtered
expire_in
6hrs
expire_in
6hrs
@@ -58,6 +58,7 @@ test_germlines:
test_algo_unit
test_algo_unit
stage
test_unit
stage
test_unit
script
make -C algo unit_coverage
script
artifacts
*lcov_artifact
*lcov_artifact
only
only
/^feature-.*a.*\/.*$/
@@ -67,16 +68,17 @@ test_algo_should:
stage
test_functional
stage
test_functional
script
make -C algo should_coverage
script
artifacts
artifacts
*lcov_artifact
reports
reports
junit
algo/tests/should.xml
junit
only
only
schedules
schedules
*lcov_artifact
test_algo_shouldvdj
test_algo_shouldvdj
stage
test_shouldvdj
stage
test_shouldvdj
script
make -C algo shouldvdj_coverage
script
artifacts
*lcov_artifact
*lcov_artifact
only
only
