Commit 5033bb6b authored by Mathieu Giraud's avatar Mathieu Giraud
doc/algo.org: 'make test' is optional
parent 2b0f2474
...@@ -138,7 +138,7 @@ make germline ...@@ -138,7 +138,7 @@ make germline
# Nucl. Acids Res., 29, 207-209 (2001). PMID: 11125093 # Nucl. Acids Res., 29, 207-209 (2001). PMID: 11125093
make # compile Vijil make # compile Vijil
make test # run self-tests make test # (optional) run self-tests (can take 5 to 60 minutes)
./vidjil -h # display help/usage ./vidjil -h # display help/usage
#+END_SRC #+END_SRC
