Attention une mise à jour du service Gitlab va être effectuée le mardi 18 janvier (et non lundi 17 comme annoncé précédemment) entre 18h00 et 18h30. Cette mise à jour va générer une interruption du service dont nous ne maîtrisons pas complètement la durée mais qui ne devrait pas excéder quelques minutes.
Commit 4a294bb0 authored by Mikaël Salson's avatar Mikaël Salson
Merge branch 'feature-a/release' into 'dev'
vidjil-algo: release 2020.04
See merge request !674
parents 6dd6c7ac 0546afcc
Pipeline #141269 passed with stage
in 9 seconds
...@@ -182,8 +182,10 @@ void Germline::new_index(IndexTypes type) ...@@ -182,8 +182,10 @@ void Germline::new_index(IndexTypes type)
void Germline::set_index(IKmerStore<KmerAffect> *_index) void Germline::set_index(IKmerStore<KmerAffect> *_index)
index = _index; if (index != _index) {
index->refs++ ; index = _index;
index->refs++ ;
This changelog concerns vijil-algo, the algorithmic part (C++) of the Vidjil platform. This changelog concerns vijil-algo, the algorithmic part (C++) of the Vidjil platform.
2020-04-29 The Vidjil Team
* New --gz option to output compressed files #4253 #4269 #4270
* Improved seed framework, with different seeds on V/D/J parts. Analysis will be improved in further releases #3954
* Bugs closed (missing affectations #4225, crash in rare cases #4263)
* New Docker framework for tests on multiple compilers #4203
* New and updated tests
2020-01-24 The Vidjil Team 2020-01-24 The Vidjil Team
* Improved e-value estimation, -e is now the global e-value, new advanced option --e-value-kmer * Improved e-value estimation, -e is now the global e-value, new advanced option --e-value-kmer
Sequences on larger datasets will now be better analyzed #3594 !538 Sequences on larger datasets will now be better analyzed #3594 !538
# vidjil-algo 2020.01 # vidjil-algo 2020.04
**Command-line manual** **Command-line manual**
*The Vidjil team (Mathieu, Mikaël, Aurélien, Florian, Marc, Tatiana and Rayan)* *The Vidjil team (Mathieu, Mikaël, Aurélien, Florian, Marc, Tatiana and Rayan)*
Vidjil -- High-throughput Analysis of V(D)J Immune Repertoire -- [[http://www.vidjil.org]] Vidjil -- High-throughput Analysis of V(D)J Immune Repertoire -- [[http://www.vidjil.org]]
Copyright (C) 2011-2019 by Bonsai bioinformatics Copyright (C) 2011-2020 by Bonsai bioinformatics
at CRIStAL (UMR CNRS 9189, Université Lille) and Inria Lille at CRIStAL (UMR CNRS 9189, Université Lille) and Inria Lille
and VidjilNet consortium. and VidjilNet consortium.
contact@vidjil.org contact@vidjil.org
