Commit 47fe2dbe authored by Mathieu Giraud's avatar Mathieu Giraud
*.py: code cleaning, != is deprecated
Thanks to landscape.io.
parent 9008dc69
...@@ -230,7 +230,7 @@ def cleanup_json_sample(json_string): ...@@ -230,7 +230,7 @@ def cleanup_json_sample(json_string):
corresponding_delimiter = start_delimiters[end_delimiters.index(char)] corresponding_delimiter = start_delimiters[end_delimiters.index(char)]
except ValueError: except ValueError:
corresponding_delimiter = None corresponding_delimiter = None
if len(delimiter_stack) == 0 or delimiter_stack[-1][0] <> corresponding_delimiter: if len(delimiter_stack) == 0 or delimiter_stack[-1][0] != corresponding_delimiter:
delimiter_stack.append(char) delimiter_stack.append(char)
else: else:
delimiter_stack.pop() delimiter_stack.pop()
...@@ -238,7 +238,7 @@ def cleanup_json_sample(json_string): ...@@ -238,7 +238,7 @@ def cleanup_json_sample(json_string):
elif char == ',': elif char == ',':
pos_isolated_comma = i pos_isolated_comma = i
if pos_isolated_comma <> None: if pos_isolated_comma != None:
json_string = json_string[:pos_isolated_comma] json_string = json_string[:pos_isolated_comma]
json_string = json_string.strip() json_string = json_string.strip()
...@@ -255,7 +255,7 @@ def cleanup_json_sample(json_string): ...@@ -255,7 +255,7 @@ def cleanup_json_sample(json_string):
if last_colon == len(json_string)-1\ if last_colon == len(json_string)-1\
or property_start > last_colon: or property_start > last_colon:
json_string = json_string[:property_start+1] json_string = json_string[:property_start+1]
if len(end_delimiter_stack) > 1 and end_delimiter_stack[0] <> '}': if len(end_delimiter_stack) > 1 and end_delimiter_stack[0] != '}':
end_delimiter_stack.pop(0) end_delimiter_stack.pop(0)
