Commit 445f2ce8 authored by marc duez's avatar marc duez
migrator.py : handle file copy error
parent e9393969
...@@ -247,8 +247,11 @@ def copy_files(data, src, dest, log=MigrateLogger()): ...@@ -247,8 +247,11 @@ def copy_files(data, src, dest, log=MigrateLogger()):
for t in file_fields: for t in file_fields:
for entry in data[t]: for entry in data[t]:
if (data[t][entry][file_fields[t]] is not None): if (data[t][entry][file_fields[t]] is not None):
log.debug("Copying %s" % data[t][entry][file_fields[t]]) try:
copy(src + '/' + data[t][entry][file_fields[t]], dest + '/' + data[t][entry][file_fields[t]]) copy(src + '/' + data[t][entry][file_fields[t]], dest + '/' + data[t][entry][file_fields[t]])
except:
log.error("failed to copy file %s" % data[t][entry][file_fields[t]])
def export_peripheral_data(extractor, data_dict, sample_set_ids, log=MigrateLogger()): def export_peripheral_data(extractor, data_dict, sample_set_ids, log=MigrateLogger()):
sequence_rows = extractor.getSequenceFiles(sample_set_ids) sequence_rows = extractor.getSequenceFiles(sample_set_ids)
