Commit 42aa9ea6 authored by Mathieu Giraud's avatar Mathieu Giraud
clone.js: getHtmlInfo(), display normalized_reads when applicable
closes #3662
parent 8cce9045
...@@ -1200,10 +1200,17 @@ Clone.prototype = { ...@@ -1200,10 +1200,17 @@ Clone.prototype = {
html += row_1("clone name", this.getName()) html += row_1("clone name", this.getName())
html += row_1("clone short name", this.getShortName()) html += row_1("clone short name", this.getShortName())
html += "<tr><td>clone size (n-reads (total reads))</td>" html += "<tr><td>clone size (n-reads (total reads))"
if (this.normalized_reads && this.m.normalization_mode == this.m.NORM_EXTERNAL) {
html += "<br />[normalized]"
html += "</td>"
for (var j = 0; j < time_length; j++) { for (var j = 0; j < time_length; j++) {
html += "<td>" html += "<td>"
html += this.getReads(this.m.samples.order[j]) + " (" + this.m.reads.segmented[this.m.samples.order[j]] + ")" html += this.getRawReads(this.m.samples.order[j]) + " (" + this.m.reads.segmented[this.m.samples.order[j]] + ")"
html += "<br />[" + this.getReads(this.m.samples.order[j]).toFixed(2) + "]"
if ($('#debug_menu').is(':visible') && (typeof this.m.db_key.config != 'undefined' )) { if ($('#debug_menu').is(':visible') && (typeof this.m.db_key.config != 'undefined' )) {
html += "<br/>" html += "<br/>"
call_reads = "db.call('default/run_request', { " call_reads = "db.call('default/run_request', { "
