Commit 4207a737 authored by Marc Duez's avatar Marc Duez
parents 6a18d962 d4fa3aa1
...@@ -8,8 +8,9 @@ import ansi ...@@ -8,8 +8,9 @@ import ansi
import argparse import argparse
parser = argparse.ArgumentParser() parser = argparse.ArgumentParser()
parser.add_argument('--nb', '-n', type=int, default=5, help='number of clones to display from the first file (%(default)d)') parser.add_argument('--nb', '-n', type=int, default=5, help='number of clones to display from the first file (%(default)d), 0 for all')
parser.add_argument('--nb_others', '-o', type=int, default=3, help='number of clones to display from the other files (%(default)d)') parser.add_argument('--nb_others', '-o', type=int, default=3, help='number of clones to display from the other files (%(default)d)')
parser.add_argument('--common', '-c', action='store_true', help='display common clones instead of different clones')
parser.add_argument('--verbose', '-v', action='store_true', help='verbose output') parser.add_argument('--verbose', '-v', action='store_true', help='verbose output')
parser.add_argument('file', nargs=2, help='''.vidjil files to be compared''') parser.add_argument('file', nargs=2, help='''.vidjil files to be compared''')
...@@ -41,7 +42,16 @@ def format_rank_nb_reads(rank, list_nb_reads, list_total_nb_reads): ...@@ -41,7 +42,16 @@ def format_rank_nb_reads(rank, list_nb_reads, list_total_nb_reads):
s += ' %6d %6.2f%%' % (nb_reads, 100*float(nb_reads)/float(total_nb_reads)) s += ' %6d %6.2f%%' % (nb_reads, 100*float(nb_reads)/float(total_nb_reads))
return s return s
def common_two_clones(self, other, seg=[1000000]):
if not other or not self:
return
print self.d['id'], '\t', format_rank_nb_reads(self.d['top'], self.d['reads'], seg), format_rank_nb_reads(other.d['top'], other.d['reads'], seg)
def diff_two_clones(self, other): def diff_two_clones(self, other):
if not other or not self: if not other or not self:
who = "+-"[not other] who = "+-"[not other]
print DIFF_COLORS[who]+who, print DIFF_COLORS[who]+who,
...@@ -93,8 +103,13 @@ def compare(data1, data2, args): ...@@ -93,8 +103,13 @@ def compare(data1, data2, args):
displayed_clones.append(clone) displayed_clones.append(clone)
if args.verbose: if args.verbose:
print print
diff_two_clones(other_clones[0], other_clones[1] if len(other_clones) > 1 else None) if args.common:
common_two_clones(other_clones[0], other_clones[1] if len(other_clones) > 1 else None)
else:
...@@ -105,7 +120,9 @@ def compare(data1, data2, args): ...@@ -105,7 +120,9 @@ def compare(data1, data2, args):
print "==== Diff from %s, %d first clones" % (data1, args.nb) print "==== Diff from %s, %d first clones" % (data1, args.nb)
for id in ids_1[:args.nb]: ids_1_cut = ids_1[:args.nb] if args.nb else ids_1
for id in ids_1_cut:
print_clone_in_self_and_others(id) print_clone_in_self_and_others(id)
### Display clones of other ListWindows not present in this ListWindows ### Display clones of other ListWindows not present in this ListWindows
