Commit 410926e3 authored by Mathieu Giraud's avatar Mathieu Giraud
Makefile: use a somewhat canonical way to ignore errors
parent b4efaed2
...@@ -42,12 +42,12 @@ all: core $(EXEC) ...@@ -42,12 +42,12 @@ all: core $(EXEC)
snapshot: snapshot:
mkdir -p $(SNAPSHOTS_DIR) mkdir -p $(SNAPSHOTS_DIR)
grep --no-messages . out-*.log should-get-tests/*.log should-vdj-tests/*.log > $(SNAPSHOT) || true -grep --no-messages . out-*.log should-get-tests/*.log should-vdj-tests/*.log > $(SNAPSHOT)
snapshot_success: snapshot snapshot_success: snapshot
touch snapshot-last ; mv snapshot-last snapshot-prev touch snapshot-last ; mv snapshot-last snapshot-prev
ln -s $(SNAPSHOT) snapshot-last ln -s $(SNAPSHOT) snapshot-last
(which diffstat && make snapshot_diff | diffstat -cC) || true -(which diffstat && make snapshot_diff | diffstat -cC)
# Diff between the two last succeeded snasphots # Diff between the two last succeeded snasphots
snapshot_diff: snapshot_diff:
...@@ -85,7 +85,7 @@ shouldvdj_with_rc_merged: ...@@ -85,7 +85,7 @@ shouldvdj_with_rc_merged:
# When the global test suite is passing, individual failed tests (counted in SHOULD_*_EXPECTED_FAILS) # When the global test suite is passing, individual failed tests (counted in SHOULD_*_EXPECTED_FAILS)
# can be marked as 'TODO' to make continuous integration happy # can be marked as 'TODO' to make continuous integration happy
mark_failed_tests_as_todo: mark_failed_tests_as_todo:
sed "s/^\(not ok [0-9]*\) /\1 # TODO ##/" -i */*.tap || true -sed "s/^\(not ok [0-9]*\) /\1 # TODO ##/" -i */*.tap
curatedvdj_archive: curated-vdj.zip curatedvdj_archive: curated-vdj.zip
curated-vdj.zip: $(SHOULD_VDJ_ARCHIVE) curated-vdj.zip: $(SHOULD_VDJ_ARCHIVE)
Supports Markdown
