Commit 40c99d4e authored by Mathieu Giraud's avatar Mathieu Giraud
views/*: bikeshedding, batch patient/run/set creation
parent 1611f363
...@@ -12,7 +12,7 @@ ...@@ -12,7 +12,7 @@
value="{{if set is not None:}}{{=set['name']}}{{pass}}" required placeholder="Name"> value="{{if set is not None:}}{{=set['name']}}{{pass}}" required placeholder="Name">
</div> </div>
<div class="field_div"> <div class="field_div">
<textarea <input
onfocus="$(this).data('group-ids', [$('#group_select option:selected').val()]); onfocus="$(this).data('group-ids', [$('#group_select option:selected').val()]);
new VidjilAutoComplete().setupAtWho(this);" new VidjilAutoComplete().setupAtWho(this);"
data-needs-atwho="true" data-needs-atwho="true"
...@@ -20,5 +20,5 @@ ...@@ -20,5 +20,5 @@
id="sample_set_info_{{=i}}" id="sample_set_info_{{=i}}"
name="generic[{{=i}}][info]" name="generic[{{=i}}][info]"
rows="1" rows="1"
placeholder="Info">{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}</textarea> placeholder="set information (#tags can be used)">{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}</input>
</div> </div>
...@@ -8,7 +8,7 @@ ...@@ -8,7 +8,7 @@
<div>{{=", ".join(set['message'])}}</div> <div>{{=", ".join(set['message'])}}</div>
{{ pass }} {{ pass }}
<input class="form-control" id="patient_id_label_{{=i}}" name="patient[{{=i}}][id_label]" type="text" <input class="stringid form-control" id="patient_id_label_{{=i}}" name="patient[{{=i}}][id_label]" type="text"
value="{{if set is not None and set['id_label'] is not None:}}{{=set['id_label']}}{{pass}}" placeholder="Patient ID"> value="{{if set is not None and set['id_label'] is not None:}}{{=set['id_label']}}{{pass}}" placeholder="Patient ID">
</div> </div>
...@@ -25,7 +25,7 @@ ...@@ -25,7 +25,7 @@
title="birth date" pattern="(?:19|20)[0-9]{2}-(?:(?:0[1-9]|1[0-2])-(?:0[1-9]|1[0-9]|2[0-9])|(?:(?!02)(?:0[1-9]|1[0-2])-(?:30))|(?:(?:0[13578]|1[02])-31))" placeholder="yyyy-mm-dd"> title="birth date" pattern="(?:19|20)[0-9]{2}-(?:(?:0[1-9]|1[0-2])-(?:0[1-9]|1[0-9]|2[0-9])|(?:(?!02)(?:0[1-9]|1[0-2])-(?:30))|(?:(?:0[13578]|1[02])-31))" placeholder="yyyy-mm-dd">
</div> </div>
<textarea <input
onfocus="$(this).data('keys', [$('#group_select option:selected').val()]); onfocus="$(this).data('keys', [$('#group_select option:selected').val()]);
new VidjilAutoComplete().setupTags(this);" new VidjilAutoComplete().setupTags(this);"
...@@ -33,5 +33,5 @@ ...@@ -33,5 +33,5 @@
id="patient_info_{{=i}}" id="patient_info_{{=i}}"
name="patient[{{=i}}][info]" name="patient[{{=i}}][info]"
rows="1" rows="1"
placeholder="Info">{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}</textarea> placeholder="patient information (#tags can be used)">{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}</input>
</div> </div>
...@@ -8,12 +8,12 @@ ...@@ -8,12 +8,12 @@
<input class="form-control" id="run_id_label_{{=i}}" name="run[{{=i}}][id_label]" type="text" <input class="stringid form-control" id="run_id_label_{{=i}}" name="run[{{=i}}][id_label]" type="text"
value="{{if set is not None and set['id_label'] is not None:}}{{=set['id_label']}}{{pass}}" placeholder="Run ID"><span></span> value="{{if set is not None and set['id_label'] is not None:}}{{=set['id_label']}}{{pass}}" placeholder="run ID"><span></span>
</div> </div>
<input class="string form-control" id="run_name_{{=i}}" name="run[{{=i}}][name]" type="text" <input class="string form-control" id="run_name_{{=i}}" name="run[{{=i}}][name]" type="text"
value="{{if set is not None:}}{{=set['name']}}{{pass}}" required placeholder="Name"> value="{{if set is not None:}}{{=set['name']}}{{pass}}" required placeholder="run name">
</div> </div>
<input id="run_date_{{=i}}" name="run[{{=i}}][run_date]" type="text" class="date form-control" <input id="run_date_{{=i}}" name="run[{{=i}}][run_date]" type="text" class="date form-control"
...@@ -21,7 +21,7 @@ ...@@ -21,7 +21,7 @@
placeholder="yyyy-mm-dd" title="run date" pattern="(?:19|20)[0-9]{2}-(?:(?:0[1-9]|1[0-2])-(?:0[1-9]|1[0-9]|2[0-9])|(?:(?!02)(?:0[1-9]|1[0-2])-(?:30))|(?:(?:0[13578]|1[02])-31))"> placeholder="yyyy-mm-dd" title="run date" pattern="(?:19|20)[0-9]{2}-(?:(?:0[1-9]|1[0-2])-(?:0[1-9]|1[0-9]|2[0-9])|(?:(?!02)(?:0[1-9]|1[0-2])-(?:30))|(?:(?:0[13578]|1[02])-31))">
</div> </div>
<textarea <input
...@@ -29,13 +29,14 @@ ...@@ -29,13 +29,14 @@
id="run_info_{{=i}}" id="run_info_{{=i}}"
name="run[{{=i}}][info]" name="run[{{=i}}][info]"
rows="1" rows="1"
placeholder="Info">{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}</textarea> placeholder="run information (#tags can be used)">{{if set is not None and set['info'] is not None:}}{{=set['info']}}{{pass}}</input>
</div> </div>
<input id="run_sequencer_{{=i}}" name="run[{{=i}}][sequencer]" type="text" class="form-control" <input id="run_sequencer_{{=i}}" name="run[{{=i}}][sequencer]" type="text" class="form-control sequencer"
value="{{if set is not None and set['sequencer'] is not None:}}{{=set['sequencer']}}{{pass}}" placeholder="Sequencer"> value="{{if set is not None and set['sequencer'] is not None:}}{{=set['sequencer']}}{{pass}}" placeholder="sequencer">
</div> </div>
<input id="run_pcr_{{=i}}" name="run[{{=i}}][pcr]" type="text" class="form-control" <input id="run_pcr_{{=i}}" name="run[{{=i}}][pcr]" type="text" class="form-control pcr"
value="{{if set is not None and set['pcr'] is not None:}}{{=set['pcr']}}{{pass}}" placeholder="PCR"> value="{{if set is not None and set['pcr'] is not None:}}{{=set['pcr']}}{{pass}}" placeholder="primers, capture...">
</div> </div>
{{extend 'db_layout.html'}} {{extend 'db_layout.html'}}
<h3>Add patients, runs, or sets</h3>
<form id="object_form" action="DB_ADDRESS/sample_set/submit" enctype="multipart/form-data" method="post"> <form id="object_form" action="DB_ADDRESS/sample_set/submit" enctype="multipart/form-data" method="post">
<div {{ if len(groups) <= 1: }} class="hiddenCheckBox" {{pass}}> <div {{ if len(groups) <= 1: }} class="hiddenCheckBox" {{pass}}>
<label for="group_select" id="patient_group__label">Owner Group: </label> <label for="group_select" id="patient_group__label">Owner Group: </label>
{{= SELECT(*[OPTION(g['name'], _value=g['id']) for g in groups], _id="group_select", _name="group", _value=master_group, value=master_group) }} {{= SELECT(*[OPTION(g['name'], _value=g['id']) for g in groups], _id="group_select", _name="group", _value=master_group, value=master_group) }}
</div> </div>
<div class="buttons_add_elements"> <div class="buttons_add_elements">
<span class="button" Patients, runs and sets are different ways to group samples.
You can create at once several of these sets:
<span class="button2"
onclick="document.getElementById('fieldset_container').appendChild(new PatientFormBuilder().build(this.dataset.index++));" onclick="document.getElementById('fieldset_container').appendChild(new PatientFormBuilder().build(this.dataset.index++));"
id="patient_button" id="patient_button"
data-index="{{=len(sets[defs.SET_TYPE_PATIENT])}}">add patient</span> data-index="{{=len(sets[defs.SET_TYPE_PATIENT])}}">add patient</span>
<span class="button" <span class="button2"
onclick="document.getElementById('fieldset_container').appendChild(new RunFormBuilder().build(this.dataset.index++));" onclick="document.getElementById('fieldset_container').appendChild(new RunFormBuilder().build(this.dataset.index++));"
id="run_button" id="run_button"
data-index="{{=len(sets[defs.SET_TYPE_RUN])}}">add run</span> data-index="{{=len(sets[defs.SET_TYPE_RUN])}}">add run</span>
onclick="document.getElementById('fieldset_container').appendChild(new GenericFormBuilder().build(this.dataset.index++));" onclick="document.getElementById('fieldset_container').appendChild(new GenericFormBuilder().build(this.dataset.index++));"
id="generic_button" id="generic_button"
data-index="{{=len(sets[defs.SET_TYPE_GENERIC])}}">add set</span> data-index="{{=len(sets[defs.SET_TYPE_GENERIC])}}">add set</span>
...@@ -37,6 +40,3 @@ ...@@ -37,6 +40,3 @@
<input type="submit" value="save" class="btn"></td> <input type="submit" value="save" class="btn"></td>
</form> </form>
<div>
(* required fields)
</div>
