Commit 40b09210 authored by Feddal Nordine's avatar Feddal Nordine
doc/improve-docker-doc: fix command line code display error
parent 28799d66
Pipeline #154744 passed with stages
in 1 minute and 56 seconds
...@@ -160,12 +160,13 @@ You can achieve this with the following steps: ...@@ -160,12 +160,13 @@ You can achieve this with the following steps:
Note that it will trigger security warnings when accessing the client. Note that it will trigger security warnings when accessing the client.
From the `docker/` directory: From the `docker/` directory:
openssl genrsa 4096 > web2py.key openssl genrsa 4096 > web2py.key
openssl req -new -x509 -nodes -sha1 -days 1780 -key web2py.key > web2py.crt openssl req -new -x509 -nodes -sha1 -days 1780 -key web2py.key > web2py.crt
openssl x509 -noout -fingerprint -text < web2py.crt openssl x509 -noout -fingerprint -text < web2py.crt
mkdir -p vidjil-client/ssl mkdir -p vidjil-client/ssl
mv web2py.* vidjil-client/ssl/ mv web2py.* vidjil-client/ssl/
+ If you are using the `postfix` container you may want to generate certificates (using the same process) and place them in `postfix/ssl`. + If you are using the `postfix` container you may want to generate certificates (using the same process) and place them in `postfix/ssl`.
The certificates must bear the name of your mail domain (<maildomain>.crt and <maildomain>.key) The certificates must bear the name of your mail domain (<maildomain>.crt and <maildomain>.key)
