Commit 40149611 authored by Mikaël Salson's avatar Mikaël Salson
repseq_vdj.py: IgReC replaces spaces with underscores
Doing the opposite is not really satisfactory but, on the other hand, in such a case
we know the read name should contain spaces (because of the should-vdj format).
parent b6fd59da
Pipeline #86892 passed with stages
in 36 minutes and 14 seconds
...@@ -143,7 +143,7 @@ def header_igrec_results(ff_igrec): ...@@ -143,7 +143,7 @@ def header_igrec_results(ff_igrec):
while True: while True:
l = f.next() l = f.next()
result = IgReC_Result(l) result = IgReC_Result(l)
yield result['Read id'], result.to_vdj() yield result['Read id'].replace('_', ' '), result.to_vdj()
### MiXCR ### MiXCR
Supports Markdown
