GitLab
Support
Community forum
Keyboard shortcuts
vidjil
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
vidjil
vidjil
3c138657
3c138657
Mathieu Giraud
tests: test best_overlap_split
Currently, this test is not passing.
5e6bc91f
24 additions
+24
algo/tests/testSegment.cpp
+24
3c138657
@@ -11,6 +11,29 @@
@@ -11,6 +11,29 @@
using
namespace
std
using
namespace
std
void
testDynprog
// aaaaaaaTaa
// cGcccccccc
string
refA
"AAAAAAAAAA"
string
refC
"CCCCCCCCCC"
// here seqA and seqC do not actullay overlap, but the goal is to find the good split point
string
seqA
"AAAAAAATAA"
string
seqC
"CGCCCCCCCC"
int
trimA
trimC
best_overlap_split
5
seqA
seqC
refA
refC
trimA
trimC
VDJ
cout
trimA
trimC
endl
TAP_TEST
trimA
3
TEST_FINE_SEGMENT_OVERLAP
"number of trim nucleotides"
TAP_TEST
trimC
2
void
testFineSegment
void
testFineSegment
Fasta
seqV
"../../germline/IGHV.fa"
2
Fasta
seqV
2
@@ -322,5 +345,6 @@ void testSegment() {
testSegmentationCause
testExtractor
testExtractor
testProbability
testProbability
testDynprog
testFineSegment
testFineSegment
