GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
39699815
HERBERT Ryan
dev.org add database import/export doc
95657d6c
doc/dev.org
39699815
@@ -219,6 +219,22 @@ The cache is stored for each user and is updated only when a change occurs (mess
Permissions are handled by Web2py's authentication mechanism which is
specialised to Vidjil's characteristics through the =VidjilAuth= class.
** Database
*** Export
mysqldump -u <user> -p <database> --no-create-info > <file>
*** Import
In order to import the data from another you server, you need to ensure
there will be no key collision, or the import will fail.
If the database contains data, the easiest is to drop the database and
create a new empty database.
This will require you to delete the .table file in web2py/applications/vidjil/databases
In order to create the tables you should then load a page from the
webapp, but DO NOT init the database, because this will raise the problem
of colliding primary keys again.
Then run:
mysql -u <user> -p <database> < file
*** VidjilAuth
*** VidjilAuth
One VidjilAuth is launched for a given user when a controller is called.
During that call, we cache as much as possible the calls to the DB. For
