Commit 362193f0 authored by Mathieu Giraud's avatar Mathieu Giraud
doc/vidjil-format.md: corrections
Thanks to the discussion with Patrice and @espyr.
parent d218552b
Pipeline #90166 failed with stages
in 7 minutes and 46 seconds
...@@ -37,7 +37,9 @@ This is an almost minimal `.vidjil` file, describing clones in one sample. ...@@ -37,7 +37,9 @@ This is an almost minimal `.vidjil` file, describing clones in one sample.
The `seg` element is optional: clones without `seg` elements will be shown on the grid with '?/?'. The `seg` element is optional: clones without `seg` elements will be shown on the grid with '?/?'.
The `_average_read_length` is also optional, but allows to plot GENSCAN-like plots more precisely than getting only the length of the sequence. The `_average_read_length` is also optional, but allows to plot GENSCAN-like plots more precisely than getting only the length of the sequence.
All other elements are required. The `reads.germlines` list can have only one element the case of data on a unique locus. All other elements are required. The `reads.germlines` list can have only one element the case of data on a unique locus.
There is here one clone on the `TRG` locus with a designation `TRGV5*01 5/CC/0 TRGJ1*02`. There is here one clone on the `TRG` locus with a designation (`name`) `TRGV5*01 5/CC/0 TRGJ1*02`.
Note that this `name` is just used to name the clone.
The actual values used for X- and Y- axis in the V/J grid plot are `seg.5.name` and `seg.3.name` fields.
Note that other elements could be added by some program (such as `tag`, to identify some clones, Note that other elements could be added by some program (such as `tag`, to identify some clones,
or `clusters`, to further cluster some clones, see below). or `clusters`, to further cluster some clones, see below).
...@@ -65,6 +67,7 @@ or `clusters`, to further cluster some clones, see below). ...@@ -65,6 +67,7 @@ or `clusters`, to further cluster some clones, see below).
"clones": [ "clones": [
"id": "clone-001", "id": "clone-001",
"name": "TRGV5*01 5/CC/0 TRGJ1*02",
"sequence": "CTCATACACCCAGGAGGTGGAGCTGGATATTGATACTACGAAATCTAATTGAAAATGATTCTGGGGTCTATTACTGTGCCACCTGGGCCTTATTATAAGAAACTCTTTGGCAGTGGAAC", "sequence": "CTCATACACCCAGGAGGTGGAGCTGGATATTGATACTACGAAATCTAATTGAAAATGATTCTGGGGTCTATTACTGTGCCACCTGGGCCTTATTATAAGAAACTCTTTGGCAGTGGAAC",
"reads" : [ 243241 ], "reads" : [ 243241 ],
"_average_read_length": [ 119.3 ], "_average_read_length": [ 119.3 ],
...@@ -85,7 +88,7 @@ or `clusters`, to further cluster some clones, see below). ...@@ -85,7 +88,7 @@ or `clusters`, to further cluster some clones, see below).
## `.vidjil` file – several related samples ## `.vidjil` file – several related samples
This a `.vidjil` file obtained by merging with `fuse.py` two `.vidjil` files corresponding to two samples. This a `.vidjil` file obtained by merging with `fuse.py` two `.vidjil` files corresponding to two samples.
Clones that have a same `id` are gathered (see 'What is a clone?', above). Clones that are from different files but that have a same `id` are gathered (see 'What is a clone?', above).
It is the responsibility of the program generating the initial `.vidjil` files to choose these `id` to It is the responsibility of the program generating the initial `.vidjil` files to choose these `id` to
do a correct gathering. do a correct gathering.
