GitLab
What's new
7
Support
Community forum
Keyboard shortcuts
vidjil
vidjil
34ce0e63
34ce0e63
HERBERT Ryan
task.py removed log parsing and added p.wait() instead
1ff3540f
1 addition
8 deletions
+1
-8
server/web2py/applications/vidjil/models/task.py
+1
-8
34ce0e63
@@ -243,6 +243,7 @@ def run_mixcr(id_file, id_config, id_data, clean_before=False, clean_after=False
sys
stdout
flush
sys
stdout
flush
p
Popen
cmd
shell
True
stdin
PIPE
stdout
log_file
stderr
STDOUT
close_fds
True
p
Popen
cmd
shell
True
stdin
PIPE
stdout
log_file
stderr
STDOUT
close_fds
True
p
wait
print
"Output log in "
out_log
print
"Output log in "
out_log
sys
stdout
flush
sys
stdout
flush
@@ -252,14 +253,6 @@ def run_mixcr(id_file, id_config, id_data, clean_before=False, clean_after=False
alignments_filepath
os
path
abspath
out_alignments
alignments_filepath
os
path
abspath
out_alignments
results_filepath
results_filepath
try
stream
open
alignments_filepath
'rb'
print
alignments_filepath
except
IOError
print
"!!! MiXCR failed to start"
res
"message"
"[%s] c%s: MiXCR FAILED - %s"
id_data
id_config
out_folder
log
error
res
raise
IOError
## insertion dans la base de donnée
