Commit 33b20573 authored by Mathieu Giraud's avatar Mathieu Giraud
vidjil.cpp: -x/-X, fix
parent b17b78cb
...@@ -480,9 +480,9 @@ int main (int argc, char **argv) ...@@ -480,9 +480,9 @@ int main (int argc, char **argv)
"reports and segments all clones (-r 0 --ratio 0 -y " NO_LIMIT " -z " NO_LIMIT "), to be used only on very small datasets (for example -AX 20)") -> group(group); "reports and segments all clones (-r 0 --ratio 0 -y " NO_LIMIT " -z " NO_LIMIT "), to be used only on very small datasets (for example -AX 20)") -> group(group);
app.add_option("-x", max_reads_processed_sample, app.add_option("-x", max_reads_processed,
"maximal number of reads to process ('" NO_LIMIT "': no limit, default), only first reads") -> group(group) -> transform(string_NO_LIMIT); "maximal number of reads to process ('" NO_LIMIT "': no limit, default), only first reads") -> group(group) -> transform(string_NO_LIMIT);
app.add_option("-X", max_reads_processed, app.add_option("-X", max_reads_processed_sample,
"maximal number of reads to process ('" NO_LIMIT "': no limit, default), sampled reads") -> group(group) -> transform(string_NO_LIMIT); "maximal number of reads to process ('" NO_LIMIT "': no limit, default), sampled reads") -> group(group) -> transform(string_NO_LIMIT);
