Commit 32df78dd authored by HERBERT Ryan's avatar HERBERT Ryan
nginx configuration added http redirect
In order to make the change to https seemless for users, nginx will now
automatically redirect users from old http urls to the new https ones.
parent 03a00166
server { server {
listen 80; listen 80;
server_name $hostname; server_name $hostname;
return 301 https://$hostname$request_uri;
server { server {
listen 443 default_server ssl; listen 443 default_server ssl;
...@@ -62,6 +62,12 @@ gzip_types text/plain text/css application/json application/x-javascript text/xm ...@@ -62,6 +62,12 @@ gzip_types text/plain text/css application/json application/x-javascript text/xm
# Create configuration file /etc/nginx/sites-available/web2py # Create configuration file /etc/nginx/sites-available/web2py
echo "server { echo "server {
listen 80;
server_name \$hostname;
return 301 https://\$hostname$request_uri;
server {
server_name \$hostname; server_name \$hostname;
ssl_certificate /etc/nginx/ssl/web2py.crt; ssl_certificate /etc/nginx/ssl/web2py.crt;
