Commit 31b98f86 authored by marc duez's avatar marc duez Committed by Mathieu Giraud
aligner.js : code quality
parent 7789fc5b
......@@ -114,10 +114,7 @@ Aligner.prototype = {
menu.appendChild(axis_label);
$(axis_input).unbind("click");
$(axis_input).click(function(e) {
self.updateAxisBox();
e.stopPropagation();
self.connect_axisbox(axis_input);
this.selectedAxis = [Axis.prototype.getAxisProperties("productivity IMGT"),
......@@ -126,22 +123,26 @@ Aligner.prototype = {
//check axis selected in menu to update and update axisBox dom elements accordingly
updateAxisBox:function (){
connect_axisbox:function (elem){
var self = this;
var menu = document.getElementById("segmenter_axis_select");
var inputs = menu.getElementsByTagName("input");
var selectedAxis = [];
for (var i in inputs)
if (inputs[i].checked) selectedAxis.push(Axis.prototype.getAxisProperties(inputs[i].value));
if (selectedAxis.length <= 5){
self.selectedAxis = selectedAxis;
self.update();
}else{
console.log({ msg: "selection is limited to 5", type: "flash", priority: 2 });
this.checked = false;
$(elem).click(function(e) {
self.update();
}else{
connect_checkbox: function(elem, layers){
