GitLab
Support
Community forum
Keyboard shortcuts
vidjil
Project overview
Project overview
Boards
Service Desk
Operations
Operations
Incidents
Environments
Packages & Registries
Container Registry
Analytics
Analytics
Value Stream
vidjil
vidjil
2cb2d703
2cb2d703
Mathieu Giraud
core/fasta.{h,cpp}: adds (verbose=true) optional argument to some Fasta methods
637bae63
2
2 changed files
12 additions
8 deletions
+12
-8
algo/core/fasta.cpp
algo/core/fasta.cpp
+8
-5
algo/core/fasta.h
algo/core/fasta.h
+4
-3
algo/core/fasta.cpp
2cb2d703
@@ -39,31 +39,34 @@ Fasta::Fasta(int extract_field, string extract_separator)
Fasta
Fasta
const
string
input
Fasta
Fasta
const
string
input
int
extract_field
string
extract_separator
int
extract_field
string
extract_separator
bool
verbose
init
extract_field
extract_separator
init
extract_field
extract_separator
if
input
size
// Do not open empty filenames (D germline if not segmentD)
if
input
size
return
return
add
input
add
input
verbose
void
Fasta
add
istream
in
void
Fasta
add
istream
in
bool
verbose
in
this
in
this
if
verbose
cout
\t
setw
6
total_size
" bp in "
setw
3
size
" sequences"
endl
cout
\t
setw
6
total_size
" bp in "
setw
3
size
" sequences"
endl
void
Fasta
add
const
string
filename
void
Fasta
add
const
string
filename
bool
verbose
ifstream
is
filename
c_str
ifstream
is
filename
c_str
if
is
fail
if
is
fail
throw
invalid_argument
" !! Error in opening file: "
filename
throw
invalid_argument
filename
if
verbose
cout
filename
cout
filename
add
is
add
is
verbose
is
close
is
close
algo/core/fasta.h
2cb2d703
@@ -47,7 +47,8 @@ public:
* valid
* valid
Fasta
const
string
input
Fasta
const
string
input
int
extract_field
string
extract_separator
int
extract_field
string
extract_separator
bool
verbose
true
int
size
const
int
size
const
@@ -63,13 +64,13 @@ public:
* Add the content of the stream to the current object
void
add
istream
in
void
add
istream
in
bool
verbose
true
* Add the content of the file to the current object
* @throws invalid_argument if the file cannot be opened or
* if the content is not valid
void
add
const
string
filename
void
add
const
string
filename
bool
verbose
true
friend
istream
operator
istream
Fasta
friend
istream
operator
istream
Fasta
