Commit 289965df authored by Mathieu Giraud's avatar Mathieu Giraud
vidjil.cpp: -g takes either a path, or a full filename to 'germlines.data'
parent d84d1e50
...@@ -68,7 +68,8 @@ ...@@ -68,7 +68,8 @@
//$$ #define (mainly default options) //$$ #define (mainly default options)
#define DEFAULT_MULTIGERMLINE "germline" #define DEFAULT_MULTI_GERMLINE_PATH "germline/"
#define DEFAULT_MULTI_GERMLINE_FILE "germlines.data"
#define DEFAULT_READS "./data/Stanford_S22.fasta" #define DEFAULT_READS "./data/Stanford_S22.fasta"
#define DEFAULT_MIN_READS_CLONE 5 #define DEFAULT_MIN_READS_CLONE 5
...@@ -349,7 +350,9 @@ int main (int argc, char **argv) ...@@ -349,7 +350,9 @@ int main (int argc, char **argv)
bool multi_germline_one_index_per_germline = true; bool multi_germline_one_index_per_germline = true;
bool multi_germline_unexpected_recombinations_12 = false; bool multi_germline_unexpected_recombinations_12 = false;
bool multi_germline_unexpected_recombinations_1U = false; bool multi_germline_unexpected_recombinations_1U = false;
string multi_germline_file = DEFAULT_MULTIGERMLINE;
string multi_germline_path = DEFAULT_MULTI_GERMLINE_PATH;
string multi_germline_file = DEFAULT_MULTI_GERMLINE_FILE;
string forced_edges = "" ; string forced_edges = "" ;
...@@ -415,6 +418,29 @@ int main (int argc, char **argv) ...@@ -415,6 +418,29 @@ int main (int argc, char **argv)
case 'g': case 'g':
multi_germline = true; multi_germline = true;
multi_germline_file = string(optarg); multi_germline_file = string(optarg);
string arg = string(optarg);
struct stat buffer;
if (stat(arg.c_str(), &buffer) == 0)
if( buffer.st_mode & S_IFDIR )
// argument is a directory
multi_germline_path = arg ;
multi_germline_file = DEFAULT_MULTI_GERMLINE_FILE ;
else
multi_germline_path = extract_dirname(arg);
multi_germline_file = extract_basename(arg, false);
else
cerr << ERROR_STRING << "A path or a file must be given with -g" << endl ;
exit(1);
germline_system = "multi" ; germline_system = "multi" ;
break; break;
...@@ -779,7 +805,7 @@ int main (int argc, char **argv) ...@@ -779,7 +805,7 @@ int main (int argc, char **argv)
if (multi_germline) if (multi_germline)
multigermline->build_from_json(multi_germline_file, "germlines.data", GERMLINES_REGULAR, trim_sequences); multigermline->build_from_json(multi_germline_path, multi_germline_file, GERMLINES_REGULAR, trim_sequences);
else else
...@@ -825,7 +851,7 @@ int main (int argc, char **argv) ...@@ -825,7 +851,7 @@ int main (int argc, char **argv)
// Should come after the initialization of regular (and possibly pseudo) germlines // Should come after the initialization of regular (and possibly pseudo) germlines
if (multi_germline_incomplete) { if (multi_germline_incomplete) {
multigermline->one_index_per_germline = true; // Starting from now, creates new indexes multigermline->one_index_per_germline = true; // Starting from now, creates new indexes
multigermline->build_from_json(multi_germline_file, "germlines.data", GERMLINES_INCOMPLETE, trim_sequences); multigermline->build_from_json(multi_germline_path, multi_germline_file, GERMLINES_INCOMPLETE, trim_sequences);
if (multi_germline_mark) if (multi_germline_mark)
