GitLab
Menu
Support
Community forum
Keyboard shortcuts
Menu
vidjil
vidjil
276ff5e8
276ff5e8
Mikaël Salson
should-vdj-to-tap.py: doctests
dbd61c55
Pipeline
#86275
passed with stages
in 35 minutes and 53 seconds
algo/tests/should-vdj-to-tap.py
276ff5e8
@@ -248,6 +248,17 @@ def should_result_to_tap(should_pattern, result, tap_id):
True
True
>>> srtt_ok(should, other_allele)
True
True
>>> should = 'TRAV1-1 TRAJ1'
>>> other = 'TRAV1-1*01 1/ACG/3 TRAJ1*01'
>>> (args.ignore_N, args.ignore_del) = (True, True)
>>> srtt_ok(should, other)
True
>>> should = 'TRAV1-1 (TRAJ1, TRAJ2)'
True
m_locus
r_locus
search
should_pattern
m_locus
r_locus
search
should_pattern
Supports
