Commit 25a58d91 authored by Mathieu Giraud's avatar Mathieu Giraud
should-vdj-to-tap.py: fix the 'Invalid regex_pattern' error
parent fa6c17ed
...@@ -163,7 +163,7 @@ def should_pattern_to_regex(p): ...@@ -163,7 +163,7 @@ def should_pattern_to_regex(p):
try: try:
regex = re.compile(regex_pattern) regex = re.compile(regex_pattern)
except: except:
sys.stderr.write("Error. Invalid regex_pattern: " + regex) sys.stderr.write("Error. Invalid regex_pattern: " + regex_pattern)
sys.exit(4) sys.exit(4)
if args.verbose: if args.verbose:
